Axles - JeepForum.com
post #1 of 3 Old 03-21-2012, 09:47 AM Thread Starter
MentalMan
Axles
Anyone know what the best rear axle is for a 05 wrangler LJ unlimited?
MentalMan is offline
post #2 of 3 Old 03-21-2012, 10:24 AM
Peterpsc
kind of depends on your application stock, rock crawler, trail rider and so forth and your "sense" of what best means....
I have these: http://www.dynatrac.com/products/tj/ProckRock60.html
Peterpsc is offline
post #3 of 3 Old 03-21-2012, 11:01 AM
biffgnar
biffgnar's Avatar
You need to provide a bit more information than that. What type of terrain? What size tire? Engine swap? Stretch? Budget? Locked or open? What gearing you looking to run? Etc. Etc.
Personally, I'm in the process of putting in a Currie F9. Its not the Pro Rock 60, but still a pretty good axle.
Romney in 2020!
biffgnar is offline
axle , lj , unlimited
Replacing TJ axles assemblies with JK axles Panhead5 TJ Wrangler Technical Forum 14 02-09-2013 09:58 AM
Dodge axles VS Ford Axles???? Allen52105 YJ Wrangler Technical Forum 7 08-07-2009 02:23 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 11:10 AM
New JK Axles/Mopar Performance Axles Badcbr TJ Wrangler Technical Forum 8 08-21-2007 05:36 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 01:40 AM
