Axle tube seals - JeepForum.com
post #1 of 21 Old 02-14-2013, 02:19 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
Axle tube seals
Who's runs them and are they worth he money?
zte87 is offline
post #2 of 21 Old 02-15-2013, 11:47 AM
bogleparsons
I want to know also.
I mud alot.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #3 of 21 Old 02-15-2013, 12:21 PM
Ironhead
i was thinking about grabbing these as a dual purpose sleeve/tube seal, anyone set these up on a TJ? i know they have a decent following in the JK crowd
http://www.offroadevolution.com/stor...prod=EVO-44MAG
Ironhead is offline
post #4 of 21 Old 02-15-2013, 06:44 PM
Nickabis
I run the alloy USA axle tube seals. I do with my one piece axle shaft from a tj I swapped in my d30. It keeps the crap out from destroying my oil seals.
Nickabis is offline
post #5 of 21 Old 02-15-2013, 07:54 PM Thread Starter
zte87
GIVE IT THE ONION
zte87's Avatar
Does it help keep oil in?
zte87 is offline
post #6 of 21 Old 02-15-2013, 07:55 PM
squarelight94
Anticanman runs them
http://madhatters4x4.com
squarelight94 is offline
post #7 of 21 Old 02-15-2013, 08:42 PM
Jeepin72
The outer tube seals help keep junk out...and keep junk in The inner seal (pumpkin) keeps the gear oil in the pumpkin. (assuming we are talking about a dana 30 or similar).
The outer tube seal theoretically keeps junk out of the tube. It will also keep junk in if it is able to pass through. Granted, it is hard to have things pass through.
I have some Alloy USA's on my Dana 30. One came loose and the seal that presses the whole thing into the tube wore down. They would not warranty it. They said it was install error (4 wheel parts). I used some RTV adhesive to jam the sucker back in with no issues since. My tubes were clean when I did the re-install.
The rubber seal that goes around the axle shaft is worn, but I will leave it to the next owner to replace. It is a part that can be replaced.
I am building a front Dana 60 that came out of a mine truck. It's outer seal had blown. I scraped wads of junk out of the tube. Did it stop the shaft from turning. No. Did the fluid I drained from the pumpkin look horrible - yes. I cant't say what if anything migrated from the outer to the inner, but the Ford Dana 60 is built with an outer seal and an inner seal.
Jeepin72 is offline
post #8 of 21 Old 02-16-2013, 09:09 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
And he highly recommends them!!!
Luck Favours The Prepared
Anticanman is offline
post #9 of 21 Old 02-16-2013, 09:15 PM
Nickabis
Well if Anticanman recommended them, we should all use them, ha ha! All joking around, they work for me, haven't had any issues.
Nickabis is offline
post #10 of 21 Old 02-16-2013, 10:06 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I don't know about that but if I say something is crap its probably true.
post #11 of 21 Old 02-16-2013, 11:08 PM
Nickabis
One person's crap is another person's treasure
I'd have to agree, that's why we are always on this threads, to give and get info. But I don't understand why no one wants to buy jeeps for eleventy billion dollars, can't remember if that's the amount Anti posts
Nickabis is offline
post #12 of 21 Old 02-16-2013, 11:20 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
post #13 of 21 Old 02-16-2013, 11:27 PM
Nickabis
Nailed it!
Nickabis is offline
post #14 of 21 Old 02-17-2013, 12:07 AM
squarelight94
You're the Oprah of jeeps, slap your name on it and it sells like hot cakes!
post #15 of 21 Old 02-17-2013, 08:14 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I just peed myself.
