Anyone with an electric fan - JeepForum.com
post #1 of 5 Old 06-03-2008, 11:49 PM Thread Starter
AlTheKillerr
AlTheKillerr's Avatar
on the outside of their jeep on the front grill? how does it do? do you like it and would you recommend it? im assuming that you keep the stock fan as well? its going to be one hot summer this year here and id like to keep the jeep cool out on the trails.
Photographer
2000 XJ, 3.5" lift, 32s, Locked
AlTheKillerr is offline
post #2 of 5 Old 06-04-2008, 08:20 AM
BadAddetude
I think most people substitute their mechanical fan for an electric fan.
Also, the protection of being inside the engine bay is why most fans are put there. That's just the way I see it, I'm sure some run pusher fans.
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
post #3 of 5 Old 06-04-2008, 11:19 AM
jeep63
YJ Collector
jeep63's Avatar
I wired up a 'pusher' fan between the grill and radiator and I kept my factory fan too. I use the electric fan when rock crawling on very hot days. It works very well. You could wire it to a temp switch, but I just turn the fan on and off as needed.
jeep63 is offline
post #4 of 5 Old 06-04-2008, 03:36 PM Thread Starter
AlTheKillerr
where should i look at getting a pusher fan? would any electric fan work? i think i remember seeing some at advanced auto
Photographer
post #5 of 5 Old 06-05-2008, 03:36 PM
zeus87gn
1987 YJ Wrangler
I bought one at the Zoo some time ago.
It could be wired either pusher or puller.
Just be sure you wire it from the battery and not the fuse box.
Best really through a relay if you want a manual switch.
Use some large gauge wire to the relay with a good fuse.
I didn't think much of this when I wired mine from the fuse box.
What a difference in all the other electrical stuff when I rewired it.
The radio even works better now.
Not to mention the main power wire was getting warm!
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
Electric Fan and Non-electric fan Installation - Urb4nTr0ll YJ Wrangler Technical Forum 19 04-07-2009 04:48 PM
Electric TJ top BChamberlin TJ Wrangler Technical Forum 14 05-30-2006 04:22 PM
Help w/ Electric Fan Prospect62 YJ Wrangler Technical Forum 3 07-04-2005 12:10 PM
To electric fan or not to electric fan daviewondr YJ Wrangler Technical Forum 9 04-22-2004 11:05 AM
Electric fan CJeepFreak84 TJ Wrangler Technical Forum 2 03-22-2004 12:30 AM
