Any tips on getting the smell out of your Jeep after it gets rained in? - JeepForum.com
post #1 of 19 Old 10-06-2013, 11:57 AM Thread Starter
Dylanm92
I have a 2007 JK and I left the top off overnight a few nights ago. I woke up at about 7:30 a.m. and it was pouring down rain. No idea how long it had been going on but, my cup holders were full of water.
Needless to say my Jeep stinks now. Any tips or tricks to get rid of the smell?
Dylanm92 is offline
post #2 of 19 Old 10-06-2013, 12:24 PM
Neo1130
2015 JK Wrangler
Lysol... Tons of it... Spray it down, wipe it up, take out carpets and air dry... Spray down again with lysol...
Neo1130 is offline
post #3 of 19 Old 10-06-2013, 12:27 PM
ChuckeCheese
Few things can work.
1. Rent an ozone generator. Very effective. Be careful and let the Jeep completely air out afterwards. Can be dangerous so read up.
2. Dryer sheets placed throughout the Jeep
3. Bowl of laundry detergent under the seat for a few days
ChuckeCheese is offline
post #4 of 19 Old 10-06-2013, 12:48 PM Thread Starter
Dylanm92
Thanks guys! I appreciate it. The smell is pretty bad lol. I've left the windows down for a couple days which has helped a bit, but not much.
Dylanm92 is offline
post #5 of 19 Old 10-06-2013, 12:58 PM
LimeLJ
LimeLJ's Avatar
The best way to do it is to remove the carpet. Make sure the floor is dry. Let the carpets dry in the sun first and then clean with carpet cleaner. Some of the carpet pieces have foam pads underneath that need to have the water pressed out to get them dry which will never happen inside the Jeep.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #6 of 19 Old 10-06-2013, 03:00 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
remove the carpet, bed-liner the tub
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 19 Old 10-06-2013, 04:47 PM
frenchy206
Eventhough I'm a huge fan of do-it-yourself Jeep projects, cleaning isn't one of them. Don't get me wrong, spending a couple hours on washing and cleaning isn't bad, however a multi day project that involves special equipment, as in your case, I'll pass. Most good detail shops have this equipment and will have it good as new in a day or two. Pay them and avoid the headache. Just my $.02
03 TJ Rubicon
frenchy206 is offline
post #8 of 19 Old 10-07-2013, 12:43 AM
Ls1man2020
Originally Posted by frenchy206 View Post
eventhough i'm a huge fan of do-it-yourself jeep projects, cleaning isn't one of them. Don't get me wrong, spending a couple hours on washing and cleaning isn't bad, however a multi day project that involves special equipment, as in your case, i'll pass. Most good detail shops have this equipment and will have it good as new in a day or two. Pay them and avoid the headache. Just my $.02
+1
Ls1man2020 is offline
post #9 of 19 Old 10-07-2013, 03:18 AM
4x4jkx
Did the same thing to my jeep. Sprayed vinegar on every piece of seat and carpet fabric and then then it air out for a few days. Smell was gone. Coffee grounds also help to remove the vinegar smell after spraying.
4x4jkx is offline
post #10 of 19 Old 10-07-2013, 06:51 AM
222Doc
222Doc's Avatar
just remove the carpet. done. I have a new carpet set still. I never put it back in. Was close to the first mod. Jeeps should not have carpet. On ours there are stickers on the front tunnel "warning hot" that you can only read with no carpet. Why the stickers? If the carpet comes factory with no delete? I wonder if Jk's are sold with out somewhere?
222Doc is offline
post #11 of 19 Old 10-07-2013, 03:56 PM
bogleparsons
A friend of mine once had a hooker in the back seat of my pontiac, it smelled funny until I sold it.
So there's that option.
Or you could remove the carpet and put the windows down till it dries out.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #12 of 19 Old 10-08-2013, 06:41 AM
vadslram
It's the carpet and padding that smells. Even if you clean it out completely and ****** it in Fabreeze every time it gets humid you will smell it...Speaking from personal experience my truck smelled like wet dog for about two years no matter what I tried until I did this:
Remove carpet and padding. THROW AWY THE OLD PADDING! Replace the padding and rent an extraction cleaner with a good deo rug cleaner for the carpet.
Or do what I did on my jeep. Remove carpet and padding throw both away and bedline the tub.
vadslram is offline
post #13 of 19 Old 10-08-2013, 10:59 AM
Adam013085
The ozone machine works wonders on smoke, not sure about the rain smell. An alternative you can do is always go topless and doorless and you won't notice it as much
Adam013085 is offline
post #14 of 19 Old 10-08-2013, 07:41 PM
WahooCreek
x2 on using vinegar. When mine got real bad one, I used a mix of water and vinegar with a scrub brush (lightly). Left it in the sun one afternoon and all was good again.
WahooCreek is offline
post #15 of 19 Old 10-09-2013, 06:07 AM
bobjp
Take out the carpets and spray them down at the car wash.
97 TJ sport.
bobjp is online now
