Aluminum wheel lug nuts get stuck - JeepForum.com
post #1 of 9 Old 09-12-2012, 05:27 AM Thread Starter
bwright1818
I bought some used, Jeep aluminum wheels, supposedly off a 1995 model. I had new tires put on, and installed by a Goodyear dealer, on my 1997. One week later, I could not remove them. I had to bring it back to Goodyear, who actually had to torch off one nut! I was mad at them, thinking they put them on to tight. So I went home, undid all of them, greased them and torqued then to 80 ft pounds....the low end of the torque range spec. One month goes by, and I can't get them off!! Every one is very, VERY tight, breaking Craftsman sockets, etc. Another lug nut is rounded off and will have to be torched. I WILL say that the nuts have the stupid little sheet metal chrome caps. I won't use THEM again.
How do I get the wrecked nut off? Any trick tips or tools?
Why do these get so freakin' stuck?
bwright1818 is offline
post #2 of 9 Old 09-12-2012, 06:01 AM
hustler905
The caps are the problem.
Hammer on the tightest socket you can get on there and use that to pull the damaged one off.
hustler905 is offline
post #3 of 9 Old 09-12-2012, 11:57 AM
gunshw301
Yep. You need different nuts....those suck. Hammer on a heavy weight socket and then use a breaker bar. Keep turning until the bolt snaps or nut comes off. Been there done that....get new lug nuts.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #4 of 9 Old 09-12-2012, 12:00 PM
Zombi
For really stuck nuts I don't even bother to mess with them anymore.
My steel wheels don't have recesses for lugs so the only time I've ever gotten a stuck nut like that I just put the 4-way on the lug and jump on it to snap the stud right off.
I keep a supply of those things since they seem to like to self destruct.
Call me Z
Originally Posted by mrbates View Post
Zombi's are in fact very unpleasant to be around, they smell, and bite--also, they eat babies.
Zombi is offline
post #5 of 9 Old 09-12-2012, 12:07 PM
mdm
Farm Wheeler
Originally Posted by bwright1818 View Post
...Why do these get so freakin' stuck?
...greased them and torqued then to 80 ft pounds...
I wonder too.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #6 of 9 Old 09-12-2012, 12:17 PM
gunshw301
Not sure. I had the same issues and swapped lug nuts and only had one do it so far afterwards and i think my buddy cross threaded that one. Shouldnt need anything like grease on the threads, maybe anti-seize, but I haven't ever used anything. Just tighten down and then retighten after a drive.
post #7 of 9 Old 09-12-2012, 12:18 PM
Zombi
You said you had aluminum wheels?
That is probably part of the reason, dissimilar metals n all that.
Call me Z
Zombi is offline
post #8 of 9 Old 09-12-2012, 06:30 PM Thread Starter
bwright1818
Thanks guys. Yeah, I thought about dissimilar metals. I'm a boat mechanic; so that's why I used anti-corrosion grease. (We don't like anti-seize because that sometimes has metal material in it, that causes more harm than good around salt water.) I have seen things under salt water for a summer that have not gotton this stuck. Goodyear said it was the heat from the brakes. Dunno. Pretty discouraging, though. I like fixing the Jeep but I don't like fixing stupid things twice. Funny; I had a CJ5 with aluminum wheels, "back in the day," and I used to have to keep checking the torque on them, or they would come loose. I just don't get it.
post #9 of 9 Old 09-12-2012, 06:37 PM
tjkj2002
2002 KJ Liberty
Your whole issue.Those torque specs are for dry threads,using any type of lube on the treads you must decrease the torque by at least 25% if not a little more.
Naturally the right side should self tighten while the lest side will self-loosen just by the tire rotating and why most big trucks use left hand and right hand thread wheels studs/lugnuts.
tjkj2002 is offline
Wheel Nuts SoCalJK JK Wrangler Technical Forum 16 05-15-2012 03:25 PM
lug nuts stuck!!!! ughh studs are spinning with lugs still on BigBlackTJ2010 TJ Wrangler Technical Forum 18 04-07-2010 07:31 PM
Aluminum Wheels with steel inserts for lug nuts??? Tuffjeeper TJ Wrangler Technical Forum 21 03-10-2010 04:54 AM
Lug Nuts...Stuck i think JeeperAbe TJ Wrangler Technical Forum 17 02-19-2007 09:15 PM
Stuck Lug Nuts DoubleUp686 TJ Wrangler Technical Forum 4 06-27-2006 09:46 AM
