Advice needed...please help - JeepForum.com
post #1 of 5 Old 02-24-2010, 01:09 PM Thread Starter
matt11
I have the option of buying a 1997 Wrangler 4cyl, 5 speed, with >90,000 miles for $2500. The problem is that the guy I'm buying it from (a co-worker of mine) said the clutch is bad and that's why it isn't running. I don't have any reason not to believe him since I saw him driving it this past fall. Any advice?
Thanks,
Matt
matt11 is offline
post #2 of 5 Old 02-24-2010, 01:27 PM Thread Starter
matt11
One other thing that confuses me about the Jeep is that it has the Sport package (at least that's what it says on the side of the vehicle). Now I'm very new to Jeeps, but I thought that the Sport package came standard with the 4.0, 6 cylinder? Am I wrong? What does the Sport package add to the vehicle?
Thanks again,
matt
matt11 is offline
post #3 of 5 Old 02-24-2010, 01:43 PM
mdm
Farm Wheeler
Sport = 4.0L engine. Are you sure it has the four cylinder? Decals are cheap and easy to slap on the side of a vehicle but I doubt anyone is going to swap a four cylinder into a TJ that came with a six cylinder. That would be a fair amount of work that would give you a loss in performance.
Even if the clutch is bad the engine should be able to start. It might need to have the battery charged but the engine should start. Give it a try, see what the clutch is actually doing, and then start working on a purchase decision.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 5 Old 02-24-2010, 02:08 PM
moonshinefuel
If it is a 4 cylinder, it has an ax5 transmission, known to be problematic. I would be hesitant if I did not have an extra ax5 around just in case that one is bad.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 5 Old 02-24-2010, 02:30 PM
Ross
In 01 the sport package had the 4.0 which was the 6.
01 TJ,33X12.5Flaken WP ATs,Winch, ARBs F&R, belly up, some armor,4.0,5spd
Ross is online now
Advice Needed! FSTG60MAN YJ Wrangler Technical Forum 12 04-30-2007 01:28 PM
Advice needed !!! ebproseller YJ Wrangler Technical Forum 8 04-04-2007 09:49 AM
Advice needed! mckaax TJ Wrangler Technical Forum 10 01-11-2007 09:36 PM
tj help (advice) needed jerryhipp TJ Wrangler Technical Forum 6 03-18-2005 08:42 PM
Advice Needed TX WJ TJ Wrangler Technical Forum 3 05-18-2003 09:23 AM
