7/70 Warranty - Drivetrain Only or Bumper to Bumper - JeepForum.com
post #1 of 8 Old 07-26-2010, 06:39 PM Thread Starter
Agar426
1974 CJ6
So, my blower motor gave out on my '05 Rubicon (not the deal where only the first three speeds give out, it won't work on any speed), and I set an appt at the dealer, but then he made a casual comment about the bumper to bumper being out of warranty, but I was heading out the door, so it didn't sink in 'til I got home.
Regardless, if the 7/70 is drivetrain only, then I will cancel my appt and go to my local shop, cuz the dealer is an hour away, and will burn a day of vacation time.
Thanks!
Agar426 is offline
post #2 of 8 Old 07-26-2010, 07:24 PM
DevilDogDoc
7/70 was powertrain only. b/b was 3 /36
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #3 of 8 Old 07-27-2010, 06:56 AM
Noxian
2011 JK Wrangler
Replace it yourself anyway, the blower motor simply has a plastic clip and the whole assembly rotates out. I did mine in the parking lot of the dealership after I got the new part from the parts department.
Noxian is offline
post #4 of 8 Old 07-27-2010, 07:15 AM Thread Starter
Agar426
1974 CJ6
That's what I figured...thanks!
Agar426 is offline
post #5 of 8 Old 07-27-2010, 07:15 AM Thread Starter
Agar426
1974 CJ6
Sounds simple enough....but what if it's not the blower? Could it be the switch? My apologies....I shouldn't have stated that the blower went out, cuz I actually don't know if that's the case. All I know is that it won't work on any speed.
Agar426 is offline
post #6 of 8 Old 07-27-2010, 08:30 AM
Noxian
2011 JK Wrangler
Usualy if its the switch it will only work in specific settings, if its the resistor same thing. If the blower motor is bad it wont work at all, or may spin very slowly on any speed.
You can easily check this your self if you have a 12volt test light or multimeter
Simply disconnect the plug going into the blower motor and plug the test light or multimeter in and see if you see voltage, if you dont then your problem is elsewhere if you do then your problem is the blower motor.
Noxian is offline
post #7 of 8 Old 07-27-2010, 08:44 AM Thread Starter
Agar426
1974 CJ6
Excellent info! Will check it out....Thanks to all!
What's irritating is that it never showed signs of going out or behaving oddly. It simply worked one day, nothing the next. No warning, no funny noises, etc.
Agar426 is offline
post #8 of 8 Old 07-27-2010, 08:51 AM
Noxian
2011 JK Wrangler
Yup that's exactly how mine died, only it was at -20C in the middle of the winter
Noxian is offline
blower motor , tj , wrangler , warranty , bumper to bumper
Voiding factory bumper to bumper warranty. CoolContractor TJ Wrangler Technical Forum 11 02-20-2009 10:49 PM
Lift Kit vs. Drivetrain Warranty? nd95450 JK Wrangler Technical Forum 16 12-20-2007 07:12 AM
Drivetrain Warranty 08 JK nd95450 JK Wrangler Technical Forum 6 11-22-2007 01:08 PM
2" BB and factory drivetrain warranty Leroy4200 TJ Wrangler Technical Forum 10 06-04-2007 06:10 PM
Drivetrain Warranty? YellowNJTJ02 TJ Wrangler Technical Forum 6 06-06-2006 06:34 PM
