4 cyl cutting out - Mechanics confused. - JeepForum.com
post #1 of 5 Old 06-13-2013, 11:29 AM Thread Starter
Cyclone5
1998 is cutting out/shutting down about 10-15 minutes into the ride. Seems to happen after reaching high temperatures. Mechanics thought it might be distributer, plugs or wires. All replaced. Problem continues. Any ideas?
Cyclone5 is offline
post #2 of 5 Old 06-13-2013, 01:12 PM
Xpress
Not sure if that year has a crank sensor, but that's usually the culprit for a cutting out issue.
All about that unibody life.
Xpress is offline
post #3 of 5 Old 06-14-2013, 09:41 AM
Siva283
It is most likely your crank position sensor or your cam position sensor. The coil is also a possibility.
Ask me how I know...
Siva283 is offline
post #4 of 5 Old 06-14-2013, 12:44 PM
LaddieHanus
On my 97 the wiring for the crank position sensor got too close to the exhaust manifold and melted the insulation enough that a bump would cause the engine to cut out. The CPS is in the transmission bell housing on the drivers side.
Laddie Hanus
2009 JKU Rubicon
97 TJ Sahara
89 YJ
2000 Dodge/Cummins Lance Camper
2004 GC Limited (Wife Jeep) 4.7 HO rebuilt 9/2016
LaddieHanus is offline
post #5 of 5 Old 06-14-2013, 07:24 PM
jokerchief462
Put something over the harness like what's in your engine bay. Use some zip ties and tape on the ends. Make sure the harness is properly positioned in the factory clamp to a bell housing bolt.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
