2011 Wrangler won't go over 20 mph - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > 2011 Wrangler won't go over 20 mph
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 07-24-2013, 08:05 AM   #1
dambuehl
I hit a large puddle on the highway this morning at 65 mph, now my 2011 Wrangler sport won't go over 20 mph. The engine doesn't hardly rev even with the accelerator pressed all the way down. Is this something that will be okay after letting it dry for a bit, or do I need to take it in? Thanks.
dambuehl is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 09:04 AM   #2
TSEJEEPERS
TSEJEEPERS's Avatar
Is your check engine light on?
It sounds like it has gone into limp mode.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 10:10 AM   #3
dambuehl
No lights are on. I'm wondering if some water didn't get in the intake.
Unread 07-24-2013, 03:00 PM   #4
frenchy206
Wow. I'll be the first on this post to crack a joke about the pentastar being the problem. Crap! Just gave away the punchline. Anyways... It could be in limp mode, but I thought the CEL would come as well. The other thing it might be is a sensor malfunction in the traction control / stability management. I doubt water in the intake would cause your issue.
03 TJ Rubicon
frenchy206 is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 03:33 PM   #5
JIMBOX
Water in the filter, but not enough to penetrate and Hydo the engine, could--
Fog up the filter enough to restrict airflow and not allow the ECU to provide more RPM/fuel--
I'd take the filter out, checkit for water and be sure, if it is soaked--either replaceit or blowdryit--
Inspect the rest of the airbox and remove any water--
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote Quick reply to this message
Unread 07-24-2013, 03:44 PM   #6
wendell
1987 YJ Wrangler
Mini van engines don't go much faster than that he he !!. If there's water in the intake, then good bye mini van motor. It does sound like limp mode, but there should be a light. I feel that some thing got wet, and maybe when it dries out, things will go back to normal, lets pray that it's so. That's why I prefer the old carbed yj's and cj's, simple systems, not much to go wrong and not so hard to figure out when it does.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 04:14 PM   #7
JIMBOX
Heh Heh, that "minivan" engine had a 21 years reliable/suitable power for Chrysler and they can rev way over 5500 rpm/w plenty of power for a jeep-
All you need to do getta CJ-2A and commute to your job, as a DD--fantastic
JIMBO
Yellow Jeep No. 683
Unread 07-24-2013, 07:44 PM   #8
jay-h
It could be any number of things. I sure wouldn't try driving it in that condition.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is online now   Reply With Quote Quick reply to this message
Unread 07-25-2013, 02:08 PM   #9
Siva283
I agree with checking the air filter. If its wet no air gets through with no air comes no rpms no rpms no speed you get the idea.
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
Unread 07-25-2013, 02:09 PM   #10
Siva283
Oh and check your gas pedal sensor since you are drive by wire.
Unread 07-25-2013, 06:22 PM   #11
AlbertaJeeper
I'm gonna have to say that's something for the dealer to look at!
AlbertaJeeper is offline   Reply With Quote Quick reply to this message
