2007 JK or 2004 Rubicon? - JeepForum.com
post #1 of 11 Old 05-14-2013, 07:49 AM Thread Starter
jrbrannan
So it maybe close to me jumping back into the Jeep world again . I am currently looking between two Jeeps, 2007 JK 2door, 2003 Rubicon. Both have around 55k miles, both have automatics and soft tops. The JK has a 2" lift and 33" tires the Rubicon has a 4" lift and 35" tires. This will be a secondary car for me that I will drive on nice days, the weekends, and take on the trail maybe 5-8 times a year. The JK is running about $2500 more, thoughts? I was leaning towards the Rubicon simply because I think it will hold it's value better but I am interested to hear what others think..
jrbrannan is offline
post #2 of 11 Old 05-14-2013, 09:44 AM
dualtjs
2011 JK Wrangler
Rubi. D44's with locking diffs make it more capable off road. The 3.8L engine isn't really an "upgrade" over the 4.0L. Take the extra $2,500 and use it for sye and other upgrades.
edit: use the cash that you save for a regear (which both will need, if it hasn't been done already).
dualtjs is offline
post #3 of 11 Old 05-14-2013, 10:02 AM Thread Starter
jrbrannan
The Rubicon has the 241 which does not need a SYE if I remember correctly. I know the axles and the lockers are better on the Rubicon, as is the engine if nothing else as a work horse that should give me a TON of miles problem free. I guess I am trying to see the comfort factor of the JK vs the upgrades on the Rubicon TJ, as well as the value down the road seeing as I hope to buy a 4 door Rubicon when the next gen Wranglers come out.
post #4 of 11 Old 05-14-2013, 11:09 AM
tyvanwie
This.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #5 of 11 Old 05-14-2013, 12:09 PM
TJDaveX
There is a chance, although slight, that the 2007 JK could have a D35 in the rear.
Even if it does have the D44 rear, unless it is also a Rubicon, it will have a D30 up front. All my friends with JK D30's have had problems with theirs. They don't seem to hold together as well as a TJ D30 with large tires.
I would get the TJ Rubicon. But, I'm biased also.
TJDaveX is offline
post #6 of 11 Old 05-14-2013, 12:24 PM Thread Starter
jrbrannan
This is the way I am leaning as well. Even though I am big guy (6'8" 225) the idea of the smaller and more simple TJ is a huge advantage. I like the JK's but they just seem almost too big, probably in the way a TJ seems too big to the people who own the old CJ-2's.
post #7 of 11 Old 05-14-2013, 12:26 PM
tyvanwie
Having owned an 08 JKU and my 98 TJ now, I don't recall the JKU having any noticeable headroom.
tyvanwie is offline
post #8 of 11 Old 05-14-2013, 12:32 PM Thread Starter
jrbrannan
I owned a 08 JKU as well, and honestly my head rested right against the roll bar at times, if I were to have gotten into an accident it would have not been pretty.
post #9 of 11 Old 05-14-2013, 12:35 PM
tyvanwie
Damn. Yeah I'm only 6' so you'd be able to tell a difference.
tyvanwie is offline
post #10 of 11 Old 05-15-2013, 11:26 AM
bdub1285
Definitely go with a Rubicon. Better engine, axles, lockers, transfer case...
2001 Jeep Wrangler Sport, 4.5" lift, Front/Rear ARB Air Lockers, Dana 30/Dana 44 axles with alloy shafts, 4.56 gears, Weld in Roll Cage, 35x12.50 Cooper Discoverer Tires
bdub1285 is offline
post #11 of 11 Old 05-22-2013, 10:27 PM
joe108
I would go with the Rubi, its ready to go with the lockers and lift. The kind of driving you are describing is like my Rubi, it's a garage queen when not wheeling, the JK you may want to do up grades to lockers, etc. which will cost you $.
joe108 is offline
