2006 Jeep Wrangler ignition trim removal - JeepForum.com
post #1 of 7 Old 03-29-2012, 08:25 AM Thread Starter
goodspirit
Hey Guys,
I'm new to the forum and need some help. Can someone tell me how to remove the plastic trim to replace an ignition switch? Particularly, I need to know how to remove the part of trim that is just behind the steering wheel? I can't seem to get that part disconnected. Any help will be appreciated. Thanks.
Six
goodspirit is offline
post #2 of 7 Old 03-29-2012, 02:13 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
Do you have a 2006 TJ or a 2007 JK or ??
JeepCares is offline
post #3 of 7 Old 03-29-2012, 05:28 PM Thread Starter
goodspirit
Hello...I have a 2006 Jeep Wrangler TJ. Thank you.
post #4 of 7 Old 03-30-2012, 08:13 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
2006 TJ Ignition Switch Removal
REMOVAL
NOTE: The ignition key must be in the key cylinder for cylinder removal. The key cylinder must be removed first before removing ignition switch.
1. Remove key cylinder.
2. Remove lower steering column cover screws and remove cover.
3. Remove the multi-function switch.
4. Disconnect the electrical connector at the rear of the ignition switch.
5. Remove the ignition switch mounting screw Figure 1. Use tamper proof Torx® bit to remove the screw.
1 - Tamper Proof Torx® Screw
2 - Ignition Switch
6. Pull the ignition switch straight out to remove from the locking tabs Figure 2
1 - Ignition Switch
2 - Locking Tabs
Figure 1 - IGNITION SWITCH MOUNTING SCREW.jpg   Figure 2 - IGNITION SWITCH TABS.jpg
post #5 of 7 Old 03-30-2012, 08:20 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
2006 TJ Ignition Control / CYLINDER, Ignition Lock/Removal
REMOVAL
1. If equipped with an automatic transmission, place shifter in PARK position.
2. Rotate key to ON position.
3. A release tang is located on bottom of key cylinder Figure 1.
Figure 1 - KEY CYLINDER RELEASE TANG
1 - KEY CYLINDER
2 - RELEASE TANG
Figure 2 - KEY CYLINDER RELEASE HOLE
1 - Lower Cover
2 - Access Hole
3 - Pin Punch
4. Position a small screwdriver or pin punch into tang access hole on bottom of steering column lower cover Figure 2.
5. Push the pin punch up while pulling key cylinder from steering column.
Figure 1 - Key Cylinder Release Tang.jpg   Fig 2 - Key Cylinder Release Hole.jpg
post #6 of 7 Old 03-30-2012, 08:26 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
2006 TJ Body / Instrument Panel / COVER, Steering Column Opening/Removal
REMOVAL
WARNING: Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
1. Disconnect and isolate the battery negative cable.
2. If the vehicle is so equipped, move the tilt steering column to the fully raised position.
3. Remove the two screws that secure the steering column opening cover to the instrument panel structural support Figure 1.
4. Using a trim stick or another suitable wide flat-bladed tool, gently pry the top of the steering column opening cover away from the instrument panel on each side of the steering column far enough to disengage the two snap clip retainers from their receptacles in the instrument panel base trim.
5. If the vehicle is so equipped, roll the top of the steering column opening cover downward far enough to access and disconnect the wire harness connector for the headlamp leveling switch from the switch connector receptacle.
6. Pull the top of the steering column opening cover rearward far enough to disengage the hinge hook formations on the lower edge of the cover from the hinge pins on the lower edge of the instrument panel.
7. Remove the steering column opening cover from the instrument panel.
Figure 1 - STEERING COLUMN OPENING COVER REMOVE/INSTALL
1 - WIRE HARNESS CONNECTOR
2 - STEERING COLUMN OPENING COVER
3 - HEADLAMP LEVELING SWITCH
4 - SCREW (2)
post #7 of 7 Old 03-30-2012, 08:30 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
goodspirit - if you didn't get what you needed from one of the three above posts (info taken from the service manual) let me know.
I'm not very technical. I can usually find directions - can't always interpret them.
Jeep Wrangler Sport 2006 xdgalx7 Wrangler General Discussion 1 10-24-2011 03:07 PM
2006 Jeep Wrangler? van77 TJ Wrangler Technical Forum 3 10-01-2010 09:41 AM
2006 Wrangler Unlimited Door Removal Mikesurf TJ Wrangler Technical Forum 4 08-02-2010 11:59 AM
Will a 2006 stock radio from a jeep wrangler fit a 1999 jeep wrangler 1954Dodge TJ Wrangler Technical Forum 2 08-16-2008 10:40 AM
The 411 on the New 2006 Jeep Wrangler JeepTales TJ Wrangler Technical Forum 16 08-12-2005 08:23 PM
