12,500lb. tuff stuff winch? - JeepForum.com
post #1 of 17 Old 12-09-2008, 09:40 PM Thread Starter
zac87
i found a 12,500lb. Tuff Stuff winch on ebay for $289. seems like a good deal but i believe you get what you pay for and i'm not big on brands that aren't proven. I've never heard of it but was wondering if anyone else was familiar?
the address is http://cgi.ebay.com/ebaymotors/NEW-1...Q5fAccessories
'97 TJ, 4.0L 5 speed, locker in front, Skyjacker 4in suspension, BFG AT 33x12.5, black cragar soft 8's, Bushwacker flares, Quick dicos, hardtop/doors, Safari doors, 2002 wrangler seats, tube bumpers front and rear, Skyjacker steering stabilizer, Tuffy glove box, cheap foglights, new paint ;)
SOLD: '88 YJ, 4.2L 5 speed, 31 bogs, KC fogs, herculined inside, straight piped
zac87 is offline
post #2 of 17 Old 12-10-2008, 04:23 PM
Skeezer
Never heard of it. I'm sure it's a generic Chinese winch. It is a series wound motor (which is good) but I wouldn't take a chance. You'll never get parts for it if you ever need them.
Superwinch makes some great affordable winches and have amazing customer service & warranties.
2005 Rubicon
Skeezer is offline
post #3 of 17 Old 12-10-2008, 04:26 PM
ET48
Just get the XRC8 or 10 smittybuilt winch. I have the XRC8 which is 8,000lbs capacity and I love it to death. Only $300 shipped and is better than a Warn in my opinion!
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline
post #4 of 17 Old 12-10-2008, 06:41 PM
Trombino
Trombino's Avatar
1978 CJ7
Doesn't hte XRC8 have a permanent magnet motor?
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #5 of 17 Old 12-10-2008, 07:41 PM
ET48
The generation 1 does have a permanent 4.1hp. Smittybuilt upped their game and came out with the new 5.5hp series wound motor for the XRC8 and 10 winch. Both have the same motor and everything, just different gears for the different capacities.
Here is my XRC8 generation 2 installed on my 1998TJ Sahara. I made my own winch plate to mount it out of 1/4" thick C-channel cut down.
Here are the XRC8 generation 2 specs:
Rated Line Pull: 8000Lbs (3630kgs)
single-lineMotor: 5.5hp Series WoundControl
: Remote Switch, 12' (3.7m) lead
Gear Train: 3-Stage Planetary
Gear Ratio: 172.8:1
Clutch: Rotating Ring Gear
Brake: Automatic In-The-Drum
Drum Size: Diameter 2.5 (63.5mm)
Length8.75 (222mm)
Wire Rope: 94' 5/16 Diameter (28m, 8.2mm Diameter)
Fairlead: 4-Way Roller
Remote Control: Included
Recommended Battery: 650CCA Minimum for Winching Battery Leads: 25mm2, 72(1.83m)
Finish: Black
Weight: 80.5Lbs (36.5Kgs)
The new Smittybilt XRC-8 Winch encompasses all the best features you would want in a winch. Every XRC-8 (8,000 LB.) winch features a 5.5HP Series Wound Motor and a Planetary Gear System with 172.8:1 gear ratio that will deliver power and reliability at a premium price. For a recovery system with the muscle and dependability to bail you out of any situation, the Smittybilt XRC-8 Winch has all the heavy duty toughness you're looking for.
Revolutionary planetary gear system boasts an 8,000 lb. line rating and 172.8:1 gear ratio
5.5 hp, 12-volt, Series Wound Motor
5/16 x 92' galvanized aircraft cable with replaceable hook included
Intuitive design ensures a simple, hassle-free installation of the Smittybilt XRC-8 Winch
A heavy duty winching system with great features at an incredible overall value
Drum size: Diameter/Length: 2.5 (63.5 mm) x 8.82 (224mm)
Mounting bolt pattern: 10 x 4.5 (4 bolts, 3/8) (254 mm x 114.3 mm)
Overall Dimension (LxWxH): 22 x 8.1 x 6.3 (557 mm x 205 mm x 160 mm)
Total shipping weight: 86 lbs (39.09 kgs)
*Roller Fairlead does not mount to Winch.
Includes Roller Fairlead, Wired Remote Control, and Hook.
Winch will not work on all aftermarket bumpers. The solenoid box may need to be moved to a different mounting location.
Here are the XRC10 winch specs:
Rated Line Pull: = 10000 lbs.
Voltage: =12V
Motor: =5.5 HP Series Wound Motor
Remote Control: = 12 Ft. Lead
3 Stage planetary gear system 218:1 gear ratio
Comes with a automatic load-holding brake
The XRC 10 is the next generation in winch features and technology. The all new 10,000 lb winch has a state of the art 5.5 HP Series Wound Motor that offers unmatched durability, overheat recovery, and a 3 Stage planetary gear sysem with a 218:1 gear ratio to deliver you the power to get you and your buddies out of any situation. All of our winches come complete with the roller fairlead, remote control, hook, and solenoid box. When winching is a part of your everyday wheeling experience, then look to the all new XRC 10 by Smittybilt to be there when you need it most.
Revolutionary planetary gear system boasts an 10,000 lb. line rating and 218:1 gear ratio
23/64 x 94' galvanized aircraft cable with replaceable hook included
Intuitive design ensures a simple, hassle-free installation of the Smittybilt XRC-10 Winch
Drum size: Diameter/Length: 2.5 (64 mm) x 8.8' (224 mm)
Overall Dimension (LxWxH): 21.15 x 6.3 x 8.6 (537 mm x 160 mm x 218 mm)
Total shipping weight: 94 lbs (42.5 kgs)
Includes Wired Remote Control, Roller Fairlead, and Hook
**Roller Fairlead Does Not Mount To Winch**
Hope this helps
ET48
ET48 is offline
post #6 of 17 Old 12-10-2008, 08:45 PM
ET48
Here is a good thread on the Smittybuilt winches with pictures and other peoples opinion on them
http://www.jeepforum.com/forum/f27/smittybilt-xrc8-winch-arrived-today-details-pictures-etc-442138/
ET48
ET48 is offline
post #7 of 17 Old 01-29-2010, 09:53 PM
johnny9
BRINGING LIFE TO A OLD THREAD..
i just got the tuff stuff 12,500 lb winch and it looks better than harbor freights lol....it comes with a few extras but you have to fab up a fairlead mount for it..it has a 6.65 hp motor thats series wound and they gave me a 3 yr warranty..it looks very similar to smittybilt winch so im sure its made in china also..but hopefully i will get my moneys worth from it..it was 279.00 and 100 for shiping..for smittybits 8000lb winch for 300 i figured id try the 12,500 for the little extra mulla..time will tell..
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #8 of 17 Old 10-19-2010, 01:51 PM
MrEddie
So 10 months later would you get a tuff stuff winch again? Im thinking of getting one too.
MrEddie is offline
post #9 of 17 Old 01-19-2011, 06:03 PM
cman3899
bump, how you liking the tuff stuff?
cman3899 is offline
post #10 of 17 Old 01-19-2011, 06:32 PM
drewrox
2010 JK Wrangler
Due to his lack of response I am assuming it does not work and he is stuck in the woods.
2010 Factory Doors for Sale!
http://www.jeepforum.com/forum/f129/2007-2011-jeep-factory-full-doors-1161706/
drewrox is offline
post #11 of 17 Old 01-19-2011, 07:41 PM
johnny9
not sure if your talkin bout my 12,500 tuff stuff or not but it has payed for itself 2-3 times imho..the hot wire near the winch has a lil melted area on the coating but other than that the abuse ive put it thru a few times has payed for it.
a while back did a 300 ft winch,hook and winch out of a quarry and went well,,done it a couple more times with no help from the jeep since the walls were very steep and not climbable,and the winch got me home..i have a bad habit of going down things i cant get back up lol
build-
johnny9 is offline
post #12 of 17 Old 01-14-2012, 09:13 PM
LftdHeep
Hey man, I've had this winch for about a year now and it has saved me a million times. I was also iffy about it but its an offbrand of xrc so I believe. The cons about it that I have ran into is have the power motor on top of the roller it will get messed up with your in the woods wheelin rolling the winch up not taking time to line the cable up, the cable will just hit the top of it and mess it up. But thats not a big deal, and the stickers on them fade quick and peal and the rollers fade too, just common. ANYWAYS the winch is strong, never failed me, and Ive used it at least a good 20 times. With the cable out to the redline.
LftdHeep is offline
post #13 of 17 Old 04-30-2012, 12:09 PM
JoseM
Well, I take it that after 4 mos since the last post, no news means good news. Feedback?
JoseM is offline
post #14 of 17 Old 05-04-2012, 11:05 AM
bobsquatch
1953 M-38
I am looking at the rough country 9500 but need a bigger winch and can get the tuff stuff for around 250. sounds like people are happy but more input would be appreciated.
bobsquatch is offline
post #15 of 17 Old 07-10-2012, 02:35 PM
Johnnyboy11788
by far the best thing ever...
I have been looking into winches now since my harbor freight "9000" burnt up on me and i have found that tuff stuff does have parts that you can order, i.e. motor, gear box, remote control, and other accessories, when it comes to winches usage, the tuff stuff 12,500 lifted a f-250 super duty 6 feet off the ground with one pulley and a 60,000 lbs strap from pep boys.
Johnnyboy11788 is offline
Tuff Stuff Winches MFARMS TJ Wrangler Technical Forum 2 12-27-2008 02:13 PM
Tuff Stuff VS. KC (Hi-Lift Mount) USCGTWEET TJ Wrangler Technical Forum 7 12-12-2007 08:01 PM
How tuff is the S35??? 1FlyGti TJ Wrangler Technical Forum 2 11-17-2006 07:06 PM
Use this stuff for your rusty bumpers & other stuff on your jeep IGotADisneyJeep TJ Wrangler Technical Forum 5 08-01-2005 03:06 PM
tuff stuff light bar hardwarp TJ Wrangler Technical Forum 3 03-31-2005 10:42 AM
