What's my Jeep worth? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Buying Forum > What's my Jeep worth?
Unread 08-12-2013, 11:08 PM   #1
oconn85
I'm thinking about selling my 92 Jeep Wrangler project and i have know idea what its might be worth. Could someone help me out? It has SOA front and triangulated 4 link rear suspension with Ford Dana44 and 9" axles, the front is set up for high steer and has a detroit trutrac but needs gears and the install kit, the rear has a brand new set of richmond 4.11 gears that need installed. It has a fuel injected Ford 5.0 v8, NP435 trans, and twin stick NP205 case. The engine and drive train have the mounts in place they just need wired in and all that good stuff. The tub was cleaned up and repainted OD green and bedliner was rolled onto the inside. The frame was repainted from the front of the tub back because i didn't have the motor mounts in place yet. It also has a hard top, full doors, custom front bumper with winch mount, custom rear bumper with tire carrier and a hood mount for a high lift jack.
oconn85 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 02:35 PM   #2
Adam013085
Its worth as much as someone will pay. If it is not running/driving you won't get a ton of $ for it. Probably more $ parting it out.
Adam013085 is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 09:05 PM   #3
Jason
Probably worth more parted than together. Figure out the price of the major parts (axles, engine, clean tub and frame) and subtract a bit for someone to take the whole thing as a package. Unfinished projects can be hard to sell.
"Ugly Betty" Build - 97 TJ 5.9 Magnum / 46RE Swap
We're men! We don't need no stinkin directions!
Jason is offline   Reply With Quote Quick reply to this message
Unread 08-15-2013, 07:04 PM   #4
brownbagg
1930 MK Compass
i say about $700
brownbagg is offline   Reply With Quote Quick reply to this message
