The value of my 1989 Islander - JeepForum.com
post #1 of 6 Old 06-25-2012, 11:31 AM Thread Starter
white sox bill
I wish I had a pic but I dont, so let me describe it: (FWIW Kelly Blue Book, which only goes back 20 yrs on vehickles, had it at $3446 using the data that best fit it, so an 1989 would be less) It has 160,000 miles, is a 4.2 straight six cylinder
The bad:
Body has 2 or 3 really bad spots, front and rear panel where you could easily put 2 fingers thru it and some other surface rust
The driver seatbelt has also rusted thru so the base of belt would need to be re-attached
Brake line is exposed on this model and at least one line is broke, but rest may be close to being broke
Needs a carb kit, but it does run
The good:
Engine has 160,000 on it but got rebuilt at about the 140,000 mark so its good to go infact it purrs pretty good
Has both hard and soft tops
Has 4 almost brand new tires
Has great CD am/fm stereo by Clarion
Has trialer hitch
Any suggestions on a fair selling price to another individual? Thanks!
1989 YJ Inline 6 cylinder 4.2 liter
white sox bill is offline
post #2 of 6 Old 06-25-2012, 11:39 AM
93jeepREDSOX
Unfortunately the bad will always out weight the good when your selling a vehicle, me personally I would list it at 4500 or best offer and see what you get. You could probably get 3500 maybe more if your good at haggling and have time to weight for the right buyer
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #3 of 6 Old 06-25-2012, 11:46 AM Thread Starter
white sox bill
I would be shocked to get that much as I havent driven it in 3 yrs....someone already low balled me at $800 LOL
post #4 of 6 Old 06-25-2012, 11:54 AM
93jeepREDSOX
Yea you could part it out for more than 800, you could probably get over 2k parting it out
The build thread
post #5 of 6 Old 06-25-2012, 12:06 PM
chico166
chico166's Avatar
Without seeing it, I'm thinking you should realistically expect to get $2k-$3k
2013 JK Unlimited Gecko Green, 4" Skyjacker lift. Pro-Comp 35" Xterrain tires
chico166 is offline
post #6 of 6 Old 06-25-2012, 07:34 PM
mazyj
Are you capable of doing any work on it yourself? I would expect to get a lot more hits on the vehicle if you were to fix that brake line and put the carburetor kit on there. Because you were forced to use a '92 Wrangler for the KBB value did you pick the four or six cylinder engine? If you picked the 4.0L then I would say that estimate is a bit high.
As it sits, at least in my area, I would expect to not get much more than $2500 for it. With those issues fixed I would expect another $1000 on top of that.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
1989 yj islander rare? wberti YJ Wrangler Technical Forum 15 01-09-2012 02:35 PM
1989 YJ Islander with 289 conversion electrical issue alpinevend YJ Wrangler Technical Forum 7 08-09-2011 01:59 PM
1989 Islander 4.2L water pump identification monkeyhouse YJ Wrangler Technical Forum 4 10-20-2009 09:50 AM
1989 yj islander questions. 84 400 YJ Wrangler Technical Forum 7 11-26-2006 06:48 PM
Anyone want an islander? Willys52 YJ Wrangler Technical Forum 3 10-28-2005 04:47 PM
