#1 | |
TOwing manual vs automatic
We're close to getting the Rubicon and need to know about towing them, is there anything special you have to do to an automatic vs the manual to tow behind a motorhome? I would like the automatic for rock crawling and ease around town but don't want a hassle when we're towing it.
Any help you can give would be appreciated
#2 |
Just violated my Parole
regardless you put the transfer-case in neutral. auto goes in park and manual goes in any gear.
#3 |
Thanks this will all be new for us
#4 |
JF is my second home.
Agreed also if you tow a lot there are many that use a device to pump the brakes when you stop to help slow it down, but if want an auto it's no problem t-case neutral, and transmission in park, do not put the transmission in neutral it could cause the transmission to turn when you drive there is not lubrication in the transmission when not running so it will destroy it. The transfer case is different even when not running the moving gears will lubricate themselves
Max 2003 Jeep Wrangler Rubicon 4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs. TJ Tech Boot Camp TJ Specs "Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track" |
#5 |
We have towed our '04 TJ (auto) many thousands of miles behind the motor home with no issues, just follow the "recreational towing" instructions in the owners manual exactly.
#6 |
Thanks appreciate the answers. Can't wait this should be a blast
#7 |
By the way, in case your wondering, they do not record mileage while being towed, DAMHIK.
#8 | |
Redleg |
#9 |
Clarified.
Here's an earlier post about this. http://www.jeepforum.com/forum/f9/2004-tj-towing-miles-676477/ |
#10 |
If you are about to buy one, consider that the lifetime warranty covers the auto but not any clutch components
--- Max 88 Comanche 09 RUBICON |
#11 |
You could tow it in reverse and see how much fun that would be... there once was a Dodge Dakota that had a transmission
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
