TJ with skyjacker 6" questions - JeepForum.com
post #1 of 2 Old 05-17-2010, 01:57 PM Thread Starter
onebigwahoo
I am thinking about buying a 2004 TJ with a 6" skyjacker kit already installed running 35" tires. The owner does not know whether it is a long arm or short arm kit. I do know that it doesn't have a sye kit on it. I want a long arm suspension on my jeep. Are there any kits that i can use to simply upgrade the suspension to a long arm i.e Rusty's or RC or RE. Also what other problems should i expect from running 35's on a short arm suspension?
thanks in advance.
onebigwahoo is offline
post #2 of 2 Old 05-20-2010, 01:38 AM
RogueSpear2023
Well with that much lift you are going to have serious drive line vibes, 4" is plenty for 35s, yes you can buy a conversion to long arm, you will also need to buy a SYE, and CV drive shaft. Short arms and 6" of lift will cause all kind of problems, I wouldn't buy it if I were you try to find something else with less modification. Also depending on the axles you may need to replace or upgrade them as well.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
6" lift , long arm upgrade , skyjacker
"05" Wrangler (Rocky Mountain Edition) TheHeilis Jeep Buying Forum 4 01-04-2010 12:28 AM
2010 Wrangler - soft top "choice" 713alan Jeep Buying Forum 4 09-17-2009 09:10 PM
"Sport" decal styles? Indicator of a difference? ShinySideUp Jeep Buying Forum 10 06-12-2009 04:10 PM
is the wrangler x "S" package enough for a daily driver? trekkindave Jeep Buying Forum 3 06-05-2009 03:09 PM
CJ-5 "Golden Eagle" model mini2nut Jeep Buying Forum 2 12-16-2008 06:28 PM
