post #1 of Old 05-07-2014, 01:38 PM Thread Starter
an3esh
Test drove a WJ overland/ some issues
Hello guys, I'm new to jeeps and SUV's in general.
Ok so I test drove a wj overland and it had problems from the startup itself, it took about 5-7 seconds of cranking the first time I started it. After it finally fired up the rpm needle kept vibrating. It was not surging like up and down 1000rpms, but just vibrating up and down maybe 50-100rpms. It is also throwing the p0174 code. What could be the issue? I turned it off and then started again, this time it fired right up.
Also with the engine in neutral I can move the 4wd selector from 4hi to n. Then when I try to move from n to 4lo it's a bit difficult. Also when I move it to 4hi from n it crunches a little.
Another problem is when I put the transmission from n to d it takes about 1 second to engage. And when I go from d to n it makes a thump.
Are all these serious issues or can be fixed easily.
an3esh is offline
You may not post new threads
You may not post replies
