Rubicon "Rear Differential Lock" indicator - JeepForum.com
post #1 of 3 Old 07-25-2013, 02:57 PM Thread Starter
fugitive
I test drove an 03 Rubicon, placed it in 4 low and pressed the differential lock toggle switch. A "rear differential lock" indicator illuminated on the instrument panel. My question is, should there also have been a "front differential lock" indication? Also, the od off switch did not illuminate nor did it prevent transmission from shifting into overdrive. Any common problems with od off switch? As-is sale.
Thanks in advance.
Fugitive
fugitive is offline
post #2 of 3 Old 07-25-2013, 02:59 PM
ItsJustD
I don't have a rubicon so I'm not too sure but I'm pretty sure you press the switch again for the front to lock. You press it once for just the rear. Not sure if there is a front differential lock light.
ItsJustD is offline
post #3 of 3 Old 07-25-2013, 03:13 PM
mrkeefer
2011 JK Wrangler
^^^^this. in 4lo you hit the locker switch for the rear. hit it again for front lock. a third to unlock. there should be a light for both lockers. alteast its that way on my '11.
mrkeefer is offline
