Researching buying a tj or jk - JeepForum.com
post #1 of 20 Old 11-30-2013, 11:07 AM Thread Starter
lanesliberty
I am looking into buying a tj or jk for a daily driver. I Like the look of the wranglers and want the 4wheel drive capability.
With that being said what are your opinions on this. I have a four year old boy who will be riding with me. I mainly drive back and forth to work and rub a few errands around town. I do occasionally go down dirt roads but no much since I don't have 4x4. I can drive a stick and considering auto or manual. Any suggestions on particular year.
lanesliberty is offline
post #2 of 20 Old 11-30-2013, 07:06 PM
Skold
JK is what you need. It is more of a comfy, city vehicle.
Skold is offline
post #3 of 20 Old 11-30-2013, 07:11 PM Thread Starter
lanesliberty
Thanks any suggestion has to options and mods. I am thinking I don't want stock wheels and tires and I've never driven a stick as a daily driver.
post #4 of 20 Old 12-01-2013, 08:07 PM
apaTJ
Are you going to mod it just for looks or to perform better off-road?
apaTJ is offline
post #5 of 20 Old 12-01-2013, 08:11 PM Thread Starter
lanesliberty
Mostly for the looks. I would like the ability to get in some mud holes occasionally. And I'm not above getting the winch out to pull me from a hole if need be.
post #6 of 20 Old 12-01-2013, 08:42 PM
apaTJ
Once you get your jeep you can consider what upgrades you want. On a jk you can fit significantly larger tires than stock without lifting it. A set of 32-33 inch all terrains and some aftermarket wheels will give the jeep a nice aggressive look different from stock and also get it a little higher off the ground for off road.
apaTJ is offline
post #7 of 20 Old 12-02-2013, 06:42 AM
mwmoon
I drove a 2005 TJ every day for five and a half years (Oct. 16, 2006, until I sold it last summer). It was such an awesome vehicle that I remember the exact date I bought it and have chosen to forget the day I got rid of it.
I just bought an '07 JKU Sahara this weekend. It looks and rides great. The extra room the four-door model provides was one of the main reasons I went with a JK instead of another TJ when I bought another Jeep.
My thoughts: Either vehicle is going to make an awesome platform to build, and both are going to be very capable even if they're bone stock. The JK does ride quite a bit better than the TJ, even with its 3.5 inch lift and 35-inch mud terrain tires. However, some JK owners would have you believe a TJ has the road manners of a farm tractor. That's not the case at all.
Do plenty of research before you jump into something. If you think you're going to keep the Jeep for a while and end up modifying it (as everyone on this forum, including me, seems to do), you're going to want the right platform. What trim is right for you? SE? Sport? X? Sahara? Rubicon? No one on the forum can tell you exactly which one will fit what you think your needs are going to be, but look into the differences in each and decide what's right for you. You'll see differences in the axles, gear ratio, etc., which may or may not be important to you and which you may not have known were even factors when considering what to buy. I know I didn't have a clue when I bought my TJ.
Another option, if you decide you prefer the TJ experience but want a little more room for you and your boy, is an Unlimited TJ (which you'll see referred to as an LJ around here).
Hope this helps.
mwmoon is offline
post #8 of 20 Old 12-02-2013, 10:35 AM Thread Starter
lanesliberty
Mwmoon this is exactly why I asked the question. I don't want to jump into something like I did with my truck I've had for years cause I had to keep it. I think something newer than 2000 is what I'm looking for. A tj is more in the price range I'm looking at.
post #9 of 20 Old 12-07-2013, 11:10 AM
gily25
Originally Posted by mwmoon
The JK does ride quite a bit better than the TJ, even with its 3.5 inch lift and 35-inch mud terrain tires. However, some JK owners would have you believe a TJ has the road manners of a farm tractor. That's not the case at all. Hope this helps.
LOL...I've used that exact expression when explaining the difference between my 1994 YJ Sahara vs my 2005 TJ, in the YJs defense it had 186k happily driven miles when I sold it and I still see it occasionally.
I can chime in a bit as I'm considering swapping to a JK. You have to decide what is going to be the most important when it comes to your Jeep. My commute doubled and I could use some comforts (suspension, steering, etc.) changes that would simply add up to too much if I tried to bring the TJ up to where I need it. Also since I'm racking up the mileage I could use so meshing with lower miles (although you can probably find a TJ with less than 60k). I've added some mods over the years but now servicing typically requires pb blaster and a busted knuckle which is one of the reasons the YJ was sold. Since you'll be modding from scratch, think about the mods you'll want and how much effort you want to put in, it'll be easier to add lift, bigger tires, etc to a newer vehicle with less worn OEM parts. On the note of mods, request catalogs from quadratec and 4wd and flip through them, see the differences in available parts and costs, that may help you decide too. As far as cost, for what certain TJ years are going for at dealer lots you can easily get a private party JK. *2 cents*
iPhone app user; excuse typos...thanx.
gily25 is offline
post #10 of 20 Old 12-07-2013, 06:05 PM Thread Starter
lanesliberty
Gily25 I really want the ground clearance the ability to take the top off on sunny days and four wheel drive. A lot of streets flood where I live and I have to find an alternate root. I got my first truck simply cause it was a truck and I could afford it. Big mistake. It was defiantly not right for me. I'm looking at probably a 05 tj unlimited have to look into packages like sport or rubicon. I would like to be able to put on bolt on kits as I don't usually have the equipment for heavy mods. Guys thanks for the advice. I'm really trying to do my homework and not get something I will have to sink a lot of money into like a friend did with his 78 CJ. He bought it cause it was 1000 and had a big motor in it. Now he's selling it go figure.
post #11 of 20 Old 12-08-2013, 05:59 AM
WDNewman
Nothing wrong with a 05 TJ. Look for one rust free everywhere and completely stock; no mods at all. Do your own mods and don't buy somebody else's idea as what a jeep should look and drive like. Always choose functionality and reliability over looks. Always.
WDNewman is offline
post #12 of 20 Old 12-08-2013, 02:14 PM Thread Starter
lanesliberty
WDNewman I live in central ms so I sure rust won't be an issue but yeah I am definitely gonna look for as close to stock as possible.
post #13 of 20 Old 12-11-2013, 01:20 PM
WDNewman
As close to stock as possible is just the ticket.
I live in central ms also, and my jeep was sold new in Atlanta and has stayed in the south ever since, so there was no rust anywhere. But we gotta remember that there are dudes who buy yankee rust on ebay or craigslist and bring em down here to sell them during deer season. Thats why you always check the rust situation. Just a couple of winters in Connecticut will pretty much wipe a jeep out.
Good luck and keep us posted.
WDNewman is offline
post #14 of 20 Old 12-13-2013, 09:46 AM
442Wrangler
In like Flynn.
442Wrangler's Avatar
JK all the way. I made the switch almost 3 years ago and don't miss my old TJ at all. Get the power options for sure (I know most people say it's for sissies but hey, call me a sissy then, I don't care).
2008 JK Rubicon
-255/80/17 BFG KM2s, 16/59 JKU springs, 2013 Rubi rims, RC stubby hybrid front bumper, XRC8 winch with synthetic line, RR evap skid, and more to come
1959 Willys Wagon
-Going to be restored and painted Plantation White and Presidential Red
"I would rather wake up in the middle of nowhere than in any city on earth."
-Steve McQueen
442Wrangler is offline
post #15 of 20 Old 12-13-2013, 01:03 PM Thread Starter
lanesliberty
Well power everything will be kinda an issue considering I want half doors so can take off during spring and fall when when weather is nice enough.
