Possible purchase of 2000 Cherokee - JeepForum.com
post #1 of 16 Old 11-23-2007, 09:31 AM Thread Starter
CapnJack
CapnJack's Avatar
Edit 11/25/07
I am looking at a 2000 Cherokee with 70,000 miles on it.
Records indicate that it was well-maintained (oil changed every 5,000 miles and transmission service at correct intervals) but it still has a very slightly leaking valve cover gasket, a slightly leaking rear main seal and a "weeping" rear differential.
Are these normal for a well-maintained Cherokee with 70,000 miles or do they indicate other problems? The interior and exterior are in exceptional shape and it doesn't look abused but looks well-maintained.
I know that the valve cover gasket is an easy fix and the dealer is fixing the seal on the differential but I don't know what a slight leak from the rear main seal could mean in the future? Thanks.
Jack
CapnJack is offline
post #2 of 16 Old 11-23-2007, 11:34 AM
XJK
The Guru of Nothing
XJK's Avatar
when looking at a jeep i consider the maintenance to be #1 on my priority list. the XJ drivetrain (properly maintained) can last 300k+, so if you buy, just buy one that you know has been maintained. It will treat you better down the road. On the XJ's the other stuff can be fixed relatively inexpensively so i wouldn't worry about that as much as the maintenance.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #3 of 16 Old 11-25-2007, 06:37 PM Thread Starter
CapnJack
CapnJack's Avatar
But what causes a rear main seal to leak
I have searched for rear main seal leak and read all the posts and replies. I only saw one person mention a possible reason for the seals leaking (crank shaft wobble or something).
I don't mind buying a Jeep with 72000 with a little leak as long as it isn't something big causing it.
Has anyone ever determined what causes the rear main seals to leak other than a lousy design?
Jack
CapnJack is offline
post #4 of 16 Old 11-25-2007, 07:32 PM
XJK
The Guru of Nothing
XJK's Avatar
as far as i know its lousy design and age, there are many rear main seal leaks its just something we have to deal with, you can DIY its a bit of a PITA but it can be done.
-Kyle
XJK is offline
post #5 of 16 Old 11-25-2007, 09:09 PM
19OlllllllO41
19OlllllllO41's Avatar
Originally Posted by NotBotYet
Edit 11/25/07
Jack
The rear main on XJ's are known to leak. Its a common thing that seems to happen to the majority of them. My XJ with 105K will drip a drop or so every now and then from the rear main. If you know the oil was changed regularly and other fluids maintained, I say go for it, 70,000 mi on a 4.0L is just breaking it in! Jeeps are like old school Harleys, they are known to mark their territory a bit!
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #6 of 16 Old 11-25-2007, 09:36 PM Thread Starter
CapnJack
CapnJack's Avatar
Thanks guys,
I'm going to buy it but I just want to make sure before I did that it didn't necessarily mean a bad crank or worse. There was so much talk on the forum about replacing the seal and almost none about the reasons. So I guessed it was a bad design.
I'm probably picking it up on Monday or Tuesday so I'll post pics when I do.
Thanks again.
Jack
CapnJack is offline
post #7 of 16 Old 11-25-2007, 10:09 PM
XJK
The Guru of Nothing
XJK's Avatar
congrats, you defiantly wont be sorry with your decision
-Kyle
XJK is offline
post #8 of 16 Old 12-09-2007, 10:07 PM
srmitchell
-Kyle
I actually know someone who owns a 90's cherokee.
It has 307k.
hahaha
srmitchell is offline
post #9 of 16 Old 12-10-2007, 06:36 AM Thread Starter
CapnJack
CapnJack's Avatar
That's great! After I pick up mine with 70,000 I have 230,000 miles to go to beat that record. There are several threads here about high miles but you have to search to find them. Maybe a sticky or section with photos and verified mileage?
CapnJack is offline
post #10 of 16 Old 12-10-2007, 06:43 PM Thread Starter
CapnJack
CapnJack's Avatar
Need to change my forum name from NotBotYet
Picked up my 2000 Cherokee Classic this afternoon. Unfortunately I won't be able to do any work on it until the weekend.
Now I need to change my forum name but I don't know how to do that?
CapnJack is offline
post #11 of 16 Old 12-10-2007, 08:04 PM
XJK
The Guru of Nothing
XJK's Avatar
buy a membership for JF and you can do that
-Kyle
XJK is offline
post #12 of 16 Old 12-10-2007, 08:45 PM Thread Starter
CapnJack
CapnJack's Avatar
Done
And I would have upgraded anyway because of the help you guys have been before I even bought a Jeep.
CapnJack is offline
post #13 of 16 Old 12-10-2007, 09:24 PM
XJK
The Guru of Nothing
XJK's Avatar
Done
well congrats
now you can go into your account settings and change your name as you like.
-Kyle
XJK is offline
post #14 of 16 Old 12-11-2007, 03:07 AM Thread Starter
CapnJack
CapnJack's Avatar
That was easy
Jack
CapnJack is offline
post #15 of 16 Old 12-11-2007, 03:50 AM
Renegade_Rick
Renegade_Rick's Avatar
"weeping" rear differential?? Humm I hope that it's just around the diff cover or plug. If your rear is a d35 and it's leaking around where the axe tubes go into the pumpkin it's not good news. So do check that out. Leaky valve covers and main seals are nomral. Just don't use syenthic oil untill you get them fixed. Syenthic oil can make leaks worse. Post any other questions in the cherokee tech forum. Thouse dudes have helped me a ton on my 99xj. Enjoy the jeep dude!
R
1999, Sport, 4-door, 4L-I6, AW4 auto, np231, 8.25 rear, dana 30 h-p.
Renegade_Rick is offline
Help with purchase of a Grand Cherokee metalhead Jeep Buying Forum 1 12-23-2009 12:29 AM
Looking to purchase 2005-2007 Grand Cherokee Chris627 Jeep Buying Forum 2 11-17-2009 03:59 AM
Looking to purchase a Grand Cherokee Matty_Fish Jeep Buying Forum 3 07-02-2009 10:30 PM
Newbee looking to purchase 01 Cherokee RichN Jeep Buying Forum 4 06-08-2008 07:24 PM
