Here are the features of the car with the MSRP being$35,125 and walking out the door price now at $35,600 and can believe I can probably get it at $35,000 once I figure out if it is a good price or not. Another dealer called me to offer me a quote and once I told them what I was told they said that if that was true to take it because they could not come close to that OTD price. Do not know if they were lying or not. Again im new to the jeep world.
ADDITIONAL EQUIPMENT• BLACK 3-PIECE HARD TOP -inc: Rear Window Defroster, Tinted Rear Quarter & Liftgate Windows, Delete Sunrider Soft Top, Freedom Panel Storage Bag, Rear Window Wiper/Washer: MX3• CONNECTIVITY GROUP -inc: Uconnect Voice Command w/Bluetooth, Vehicle Information Center, Remote USB Port, Tire Pressure Monitoring Display: AAJ• SIRIUS SATELLITE RADIO -inc: 1-Yr SIRIUSXM Radio Service, For More Info Call 888-539-7474: RSCCPOS PKG• QUICK ORDER PACKAGE 24S -inc: Engine: 3.6L V6 24V VVT, Transmission: 5-Speed Automatic (W5A580), Front 1-Touch Down Power Windows, Remote Keyless Entry, Deep Tint Sunscreen Windows, Leather Wrapped Steering Wheel, Chrome/Leather Wrapped Shift Knob, Power Heated Mirrors, Power Convenience Group, Power Locks, Wheels: 17" x 7.5" Aluminum, Tires: 17", Auto Dim Mirror w/Reading Lamp, Security Alarm: 24SENGINE• ENGINE: 3.6L V6 24V VVT : ERBPRIMARY PAINT• BLACK CLEARCOAT : PX8SEAT TYPE• BLACK, CLOTH SEATS W/ADJUSTABLE HEAD RESTRAINTS : A7X9TRANSMISSION• TRANSMISSION: 5-SPEED AUTOMATIC (W5A580) -inc: Hill Descent Control, Tip Start: DGJ Granite Crystal Metallic Clearcoat
Brakes• Brake ABS System: 4-Wheel• Brake ABS System (Second Line): 4-Wheel• Disc - Front (Yes or ): Yes• Disc - Rear (Yes or ): Yes• Front Brake Rotor Diam x Thickness: 11.9 in• Rear Brake Rotor Diam x Thickness: 11.9 inCargo Area Dimensions• Cargo Volume to Seat 1: 70.6 ft³• Cargo Volume to Seat 2: 31.5 ft³• Cargo Volume to Seat 3: 31.5 ft³Electrical• Cold Cranking Amps @ 0° F (2nd): 600• Cold Cranking Amps @ 0° F (Primary): 600• Maximum Alternator Capacity (amps): 160Emissions• Tons/yr of CO2 Emissions @ 15K mi/year: 9.8Engine• Displacement: 3.6 L/220• Engine Oil Cooler: Regular Duty• Engine Order Code: ERB• Engine Type: Regular Unleaded V-6• Fuel System: Sequential MPI• SAE Net Horsepower @ RPM: 285 @ 6400• SAE Net Torque @ RPM: 260 @ 4800Exterior Dimensions• Body Length: 0.00 ft• Height, Overall: 72.6 in• Length, Overall: 184.4 in• Liftover Height: 31.4 in• Min Ground Clearance: 8.7 in• Track Width, Front: 61.9 in• Track Width, Rear: 61.9 in• Wheelbase: 116 in• Width, Max w/o mirrors: 73.7 inFuel Tank• Aux Fuel Tank Location: Midship• Fuel Tank Capacity, Approx: 22.5 gal• Fuel Tank Location: MidshipInterior Dimensions• Front Head Room: 41.3 in• Front Hip Room: 55.6 in• Front Leg Room: 41 in• Front Shoulder Room: 55.8 in• Passenger Capacity: 5• Second Head Room: 40.4 in• Second Hip Room: 56.7 in• Second Leg Room: 37.2 in• Second Shoulder Room: 56.8 inMileage• Cruising Range - City: 360.00 mi• Cruising Range - Hwy: 472.50 mi• EPA Fuel Economy Est - City: 16 MPG• EPA Fuel Economy Est - Hwy: 21 MPG• Fuel Economy Est-Combined: 18 MPGSteering• Steering Type: Re-Circulating Ball• Turning Diameter - Curb to Curb: 41.3 ftSuspension• Axle Ratio
1) - Front: 3.21• Axle Ratio
1) - Rear: 3.21• Axle Type - Front: Non-Independent• Axle Type - Rear: Rigid Axle• Suspension Type - Front: Leading Link• Suspension Type - Rear: Trailing ArmTires• Front Tire Order Code: TRM• Front Tire Size: P225/75SR16• Rear Tire Order Code: TRM• Rear Tire Size: P225/75SR16• Revolutions/Mile @ 45 mph - Front: 712• Revolutions/Mile @ 45 mph - Rear: 712• Spare Tire Size: Full-SizeTrailering• Dead Weight Hitch - Max Tongue Wt.: 200 lbs• Dead Weight Hitch - Max Trailer Wt.: 2000 lbs• Maximum Trailering Capacity: 2000 lbs• Wt Distributing Hitch - Max Tongue Wt.: 300 lbs• Wt Distributing Hitch - Max Trailer Wt.: 2000 lbsTransmission• Drivetrain: Four Wheel Drive• Fifth Gear Ratio
1): 1.00• First Gear Ratio
1): 4.46• Fourth Gear Ratio
1): 1.25• Reverse Ratio
1): 4.06• Second Gear Ratio
1): 2.61• Sixth Gear Ratio
1): 0.80• Third Gear Ratio
1): 1.72• Trans Description Cont.: Manual w/OD• Trans Order Code: DEH• Trans Type: 6• Transfer Case Power Take Off: NoWeight Information• As Spec'd Curb Weight: 4277.00 lbs• As Spec'd Payload: 1123.00 lbs• Base Trim Weight - Front: 2238.00 lbs• Base Trim Weight - Rear: 2039.00 lbs• Curb Weight: 4277.00 lbs• Curb Weight - Front: 2238 lbs• Curb Weight - Rear: 2039 lbs• Gross Axle Weight Rating: 5775.00 lbs• Gross Axle Wt Rating - Front: 2775 lbs• Gross Axle Wt Rating - Rear: 3000 lbs• Gross Combined Wt Rating: 6427 lbs• Gross Vehicle Weight Rating: 5400.00 lbs• Maximum Payload Capacity: 1123.00 lbs• Option Weight - Front: 0.00 lbs• Option Weight - Rear: 0.00 lbs• Payload Weight Front: 0 lbs• Payload Weight Rear: 0 lbs• Reserve Axle Capacity: 1498.00 lbs• Reserve Axle Capacity - Front: 537.00 lbs• Reserve Axle Capacity - Rear: 961.00 lbs• Standard Weight - Front: 0 lbs• Standard Weight - Rear: 0 lbs• Total Option Weight: 0.00 lbs• Trim Curb Weight: 4277.00 lbsWheels• Front Wheel Material: Styled Steel• Front Wheel Size: 16 X 7 in• Rear Wheel Material: Styled Steel• Rear Wheel Size: 16 X 7 in• Spare Wheel Material: Steel• Spare Wheel Size: Full-Size in
https://www.facebook.com/#
ENTERTAINMENT• 1 LCD Monitor In The Front• 8 Speakers• Audio Jack Input for Mobile Devices• Fixed Antenna• Radio w/Seek-Scan, In-Dash Mounted Single CD, MP3 Player, Clock and Steering Wheel Controls• Radio: 130EXTERIOR• Aero-Composite Halogen Headlamps• Black Door Handles• Black Fender Flares• Black Front Bumper w/2 Tow Hooks• Black Manual Side Mirrors w/Manual Folding• Black Rear Bumper w/1 Tow Hook• Black Side Windows Trim• Body-Colored Grille• Clearcoat Paint• Conventional Rear Cargo Access• Convertible w/Fixed Roll-Over Protection• Front Fog Lamps• Full-Size Spare Tire Mounted Outside Rear• Fully Galvanized Steel Panels• Light Tinted Glass• Manual Tailgate/Rear Door Lock• Removable Rear Window• Steel Spare Wheel• Tires: P225/75R16 BSW On/Off Road• Variable Intermittent WipersINTERIOR• 2 12V DC Power Outlets• 2 Seatback Storage Pockets• 4-Way Passenger Seat -inc: Manual Recline and Fore/Aft Movement• 5 Person Seating Capacity• 6-Way Driver Seat -inc: Manual Recline, Height Adjustment and Fore/Aft Movement• 60-40 Folding Split-Bench Front Facing Fold Forward Seatback Rear Seat• Analog Display• Carpet Floor Trim, Carpet And Rubber Mat• Compass• Cruise Control w/Steering Wheel Controls• Day-Night Rearview Mirror• Delayed Accessory Power• Driver And Passenger Visor Vanity Mirrors• Fade-To-Off Interior Lighting• Front Center Armrest w/Storage• Front Cupholder• Full Carpet Floor Covering -inc: Carpet Front And Rear Floor Mats• Full Floor Console w/Locking Storage and 2 12V DC Power Outlets• Gauges -inc: Speedometer, Odometer, Engine Coolant Temp, Tachometer, Trip Odometer and Trip Computer• Instrument Panel Bin, Dashboard Storage, Driver And Passenger Door Bins• Interior Trim -inc: Metal-Look Instrument Panel Insert, Metal-Look Door Panel Insert and Metal-Look Interior Accents• Locking Cargo Area Concealed Storage• Locking Glove Box• Manual 1st Row Windows• Manual Adjustable Front Head Restraints and Fixed Rear Head Restraints• Manual Air Conditioning• Manual Rear Windows and Removable 3rd Row Windows• Manual Tilt Steering Column• Outside Temp Gauge• Rear Cupholder• Sentry Key Engine Immobilizer• Trip Computer• Urethane Gear Shift KnobMECHANICAL• 1000# Maximum Payload• 160 Amp Alternator• 2 Skid Plates• 22.5 Gal. Fuel Tank• 3.21 Rear Axle Ratio• 4-Wheel Disc Brakes w/4-Wheel ABS, Front And Rear Vented Discs, Brake Assist and Hill Hold Control• 50 State Emissions• 600CCA Maintenance-Free Battery• Auto Locking Hubs• Engine Oil Cooler• Engine: 3.6L V6 24V VVT• Front And Rear Anti-Roll Bars• Gas-Pressurized Shock Absorbers• GVWR: 5,400 lbs• Hydraulic Power-Assist Steering• Leading Link Front Suspension w/Coil Springs• Manual Transfer Case• Normal Duty Suspension• Part-Time Four-Wheel Drive• Single Stainless Steel Exhaust• Towing w/Trailer Sway Control• Trailing Arm Rear Suspension w/Coil SpringsSAFETY• ABS Traction Control• Airbag Occupancy Sensor• Dual Stage Driver And Passenger Front Airbags• Electronic Stability Control (ESC) And Roll Stability Control (RSC)• Low Tire Pressure Warning• Outboard Front Lap And Shoulder Safety Belts -inc: Rear Center 3 Point, Height Adjusters and Pretensioners• Rear Child Safety Locks• Side Impact Beams
