need some expert advice on a engine swap - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Buying Forum > need some expert advice on a engine swap
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-19-2012, 08:17 AM   #1
trevor359
hey guys im new to the site and new to jeeps. i am only 16 and my 91 jeep wranger is my first jeep and first car. i have done alot of work on it already. i got a offer from a friend of mine for a 93 jeep wrangler for parts. but it has the 6 cylinder running motor and 5 speed manual. my jeep right now has the 4 cylinder and i would love the extra power. is this even possible to do? really could use ur help. thanks guys!
trevor359 is offline   Reply With Quote
Unread 01-19-2012, 08:31 AM   #2
Jason
Sarcastic Genius
Jason's Avatar
It's very possible to do. Enlist the assistance of someone (dad, brother, grandma, whoever) with the tools and prior knowledge to give you a hand. Engine swaps are pretty major, but if you are already doing work yourself, you can do it.
However, if you can get the '93 6 cylinder, why not drive that instead of your '91 4 cylinder?
Jason is offline   Reply With Quote
Unread 01-19-2012, 09:24 AM   #3
trevor359
well i havent looked at the car at all yet, he said its not running and for parts. so im thinking ill just swap it. and my dad is really good and knows how to do this( he has rebuilt his mustang, and put like 3 motors in his old truck) he knows what he is doing i just wanted to make sure its even possible. any advice???
Unread 01-19-2012, 12:56 PM   #4
Jason
Sarcastic Genius
Jason's Avatar
I'd usually suggest having the entire donor vehicle available to take parts from. Sounds like you have that part under control. Take the grille, fenders and hood off. Wranglers are fairly straight forward. I always take tons of pics as I do anything. It helps if you have to go back and look at how something goes back together. Label everything. Good luck.
Unread 01-21-2012, 01:49 AM   #5
RogueSpear2023
IMO it would be not worth the time and effort to do the swap for the minimal power gains of the 6cyl while significant compared to the 4cyl, it still would not be worth it. You would probably be better off swapping the parts from you current 4cyl on to the 6cyl frame, and drivetrain. Engine swaps are not easy or cheap even if you get the parts for cheap. If you dad has the know to do it, they are very straight forward though.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Unread 02-27-2012, 09:15 PM   #6
Vicarious
1997 XJ Cherokee
Not running?
Am I missing something here? why is it not running? Could be a lot of expensive reasons....failed ECM? Ignition? Can you do a compression test on it? Dont get a non running donor for the motor!
Is yours auto or stick?
If you do the swap, remember you need the EMC too, wiring harness & if going auto to stick, pedals, shift etc. Motor swaps not rocket science as long as you tag EVERY wire,hose , plug & are patient. Some may do it in a day...plan for 4 and celebrate/brag if you do it in less , read,read,read!
Vicarious is offline   Reply With Quote
engine , transmission , wrangler yj
