Manual Jeep Question - JeepForum.com
post #1 of 10 Old 03-29-2013, 02:11 PM Thread Starter
BDK72
Hi all! Love the Forum!
I'm interested in buying a new Wrangler manual and noticed that the shifter is so close to the console/dash that every time I shift to 1st, 3rd or 5th, my knuckles get bashed! Does anyone else experience this problem? I'm really having a hard time with this and might be a deal breaker to getting a new jeep.
Thanks!
Saul
BDK72 is offline
post #2 of 10 Old 03-29-2013, 10:31 PM
anotherlilguy
Change your grip on the shifter? I don't have that problem at all on mine. But I also adjust my grip depending on which gear I am going to.
anotherlilguy is offline
post #3 of 10 Old 03-30-2013, 12:58 AM
LeeMasterGT
Unless your hands are freakishly massive... There is something that is causing the shifter to be in the wrong position. Have they done a tummy tuck to the Jeep? have they installed an aftermarket shift knob? Bottom line... My tranny is pushed up 1.5 inches from where it was stock because of my tummy tuck, and I still have a solid 3/4" before my hand would contact the center stack.
LeeMasterGT is online now
post #4 of 10 Old 03-30-2013, 06:08 AM
UTAH
UTAH's Avatar
I've had several manual trans Jeeps and the 2012 Rubicon is the latest. I've never noticed a clearance problem in shifting in any of them. I've had to notch the trans tunnel to accommodate body lifts, but the shift lever simply becomes lower with a body lift - it doesnot move forward any more than it used to do.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #5 of 10 Old 03-30-2013, 03:07 PM
32vld
Sounds as if the way you grip and maybe you have the seat to far forward.
32vld is offline
post #6 of 10 Old 03-30-2013, 04:15 PM
LeeMasterGT
The seat would not effect the position of the shifter coming through the floor from the transmission...
post #7 of 10 Old 03-30-2013, 08:44 PM
2jhanna
I'm not a big guy or big hands and have never had this problem or even noticed how close the shifter/knob was to the dash, but I did look today after seeing this thread.
I have at least a 2-3" gap. Like said above, I do also change my hand/grip orientation depending on whether I am shifting to 1,3,5 or 2,4,R. But I have done this for the past 40+ years of driving floor shift.
Maybe there has been some kind of lift etc done to your Jeep to change the position. A possible solution would be to remove the shifter, heat, and put a little more bend in it.
jhanna
denton county, tx
2jhanna is online now
post #8 of 10 Old 03-31-2013, 06:06 PM
silverfish91
I have a 2012 Rubicon manual and only hit the dash once
silverfish91 is offline
post #9 of 10 Old 04-01-2013, 02:36 PM
roughandtangle
I am going to go try this tonight after work. I haven't noticed this yet.
There is nothing good in anyone's signature. Especially mine.
roughandtangle is offline
post #10 of 10 Old 04-02-2013, 05:11 AM
reichard117
2014 JK Wrangler
I smash my hand off my shaker bottle when it's in the front cup holder, but never the dash.
'14 JK - Current
'00 TJ - Sold
'00 XJ - Sold
Follow me on Instagram - @thereich
reichard117 is offline
