07-06-2012, 06:06 PM
#1
looking at buying a YJ HAVE SOME QUESTIONS
I currently own a 2000 WJ. I am looking to add to the stable and found a 91 YJ with 227.000 miles. It looks in rough shape as far as paint, seats, and top. They are asking 2995 which I think is way too much. It has a 4cyl 5sp man. What do you all think would be a good amount to offer? I have not drove it yet only took a quick look. Frame does seem solid. I am basically looking for something cheap to work on but reliable enough to drive to work.
Any advice would be greatly appreciated.
Thanks
07-06-2012, 06:24 PM
#2
I paid 2800 for my 88 that has 140,000 miles and the 6 cyl standard 5 speed in it.
07-06-2012, 06:27 PM
#3
While a lot of guys do have fun with 4 cyl, it is very under powered. Recommend you hold out for a 6, you'll be glad you did.
07-06-2012, 06:33 PM
#4
2k would probably be the most you should pay for that. And it's not that the 4cyl are that under powered, it'll just cost more in gears if you ever want to step up tire size.
07-06-2012, 06:35 PM
#5
It will never get fixed.
This.
My biggest regret is not holding out for the 4.0 I6. But... the PO was willing to do a straight trade for my last vehicle, can't beat that!
Wait for a 4.0 to come along, you'll be glad you did.
I typically have nothing worthwhile to contribute to a thread, but I contribute anyway.
07-06-2012, 06:37 PM
#6
I agree hold out for the six cyl ,also look at the frame real good ,I bought mine and frame looked solid until I started poking around with a screw driver ,it didn't even look like it had more than surface rust with some factory paint faded around it ,also tranfer case skid bolt area ,long story short ,I replaced the frame
07-06-2012, 06:40 PM
#7
Power isn't really my concern. Just looking for something to fix up and drive in summer and have fun with. When I want power I can drive my WJ with the V8. I did find a 97 with the 6cyl but 5500 is more than what I want to spend. Any areas I should look at or problems to be aware of on the 91's?
07-06-2012, 06:41 PM
#8
My buddy had the 4cyl and he would be doing 55 up the hills once he got to the top he would be at 30
07-06-2012, 06:43 PM
#9
Check behind the window hinges for rust
07-06-2012, 07:24 PM
#10
The 4-cyl is just dandy to putt around town with, and does fine on the highway if you know what the limitations are. Plan ahead for your maneuvers, give yourself plenty of space, and don't expect a racer. Oh, and 5th is nearly useless. When you get going fast enough to take advantage of the OD ratio, the wind resistance is too high to see any fuel economy gains over the 6. That said, my '95 is my preferred DD over my Liberty, and it's "only" a 4-cyl. Besides, you can get a 4-cyl generally unmolested and probably a little cheaper than a comparable 6.
Go in with an offer of $1500 cash, and see where they stand.
I don't get it... Why do I enjoy driving my '80 CJ7 more than my '12 KK?
07-06-2012, 07:47 PM
#11
That is too much for a rough 4 cyl YJ.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
