Looking to buy a TJ. - JeepForum.com
post #1 of 7 Old 11-02-2013, 01:50 PM Thread Starter
skidatter
Aright, so I'm about to graduate "Power Lineman" school and since my truck is most likely not going to make the 650mi drive home ( Transmission dying ). I am wanting to buy myself my first Jeep.
I have an idea of what I want in a Jeep, but there is also a lot I don't know to look out for any help is appreciated.
My budget is around $9-10,000
I want
-As stock as possible
-Standard Trans.
-4.0L
-Prefer Hardtop, but I can manage
Mechanically speaking what should I look out for when buying a used TJ, the only thing I know to look for is worn clutch, leaks, front end damage, death wobble, drive shaft play, things like that..
skidatter is offline
post #2 of 7 Old 11-02-2013, 05:03 PM
Duck Doctor
Look for a rig with a Dana 44 rear axle (you can find pics on google). Also look very closely at the frame and undercarriage for rust issues. Pay close attention to the area around the tcase skid, underside of the front fenders, and make sure to stick your fingers inside the frame at all access points to check for rust chunks. Rust is your greatest enemy with these rigs, especially in the northeast.
Duck Doctor is offline
post #3 of 7 Old 11-02-2013, 05:09 PM
AZtrailtrider
HAHA most jeeps have those problems "Mechanically speaking what should I look out for when buying a used TJ, the only thing I know to look for is worn clutch, leaks, front end damage, death wobble, drive shaft play, things like that.. "
AZtrailtrider is offline
post #4 of 7 Old 11-02-2013, 06:15 PM Thread Starter
skidatter
Is the Dana 44 specific to only certain packages of the wrangler like Saharas & Sports?
post #5 of 7 Old 11-02-2013, 06:26 PM
Duck Doctor
Sahara and sport were offered with either the Dana 35 or 44. The "X" model was only offered with the Dana 35. Rubicon came standard with the 44.
post #6 of 7 Old 11-05-2013, 11:59 AM
jimhensley
Is the Dana 35 that big of an issue?
jimhensley is offline
post #7 of 7 Old 11-05-2013, 12:05 PM
Bmann412
It's not that big of an issue it depends on what u want to do with it. If u are going to offroad a lot and put big tires on then u would want a Dana 44. If your mainly staying on paved roads and doing light to mild off-roading then the Dana 35 should be fine
Bmann412 is offline
