Looking to buy this 1989 YJ - JeepForum.com
post #1 of 8 Old 05-12-2014, 06:28 PM Thread Starter
polybius
http://www.kijiji.ca/v-cars-trucks/c...jeep/575599375
Theres the link to the ad, im not the expert in jeeps, but If i buy this it will become my all year driver, to work/ etc. Im wondering what pros/cons will come if i decide to go thru with the buy?
I absolutely love the idea of taking my doors/top off and going for a cruise, I can do my own mechanic work to a point. I had a 93 grand cherokee as my last vehicle and it was awesome.
Is there any real problems with these jeeps? things i need to worry about?
Im a tall/bigger guy at 6'5/ 300 lbs, enough head/leg room?
polybius is offline
post #2 of 8 Old 05-12-2014, 06:33 PM
Caboose89
No problems. They just take a lot of love and maintenance. Leg room isn't great might want to test drive it. I'm 5 11 160 lbs and I drive with the seat to the second to last setting.
1989 Sahara. SOA, 35's, Locked.
Caboose89 is offline
post #3 of 8 Old 05-12-2014, 06:42 PM Thread Starter
polybius
im defiantly test driving it this Weekend, What about during the winter? what do i have to worry about, consdering its a carb engine, If i just keep a can of ether with me i should be fine?
polybius is offline
post #4 of 8 Old 05-12-2014, 10:47 PM
Caboose89
We get below zero a couple times around here and my 89 does fine. I have a new carb on it but before that I never had a problem. Only fuel issues I have had was I got a carb from a junk yard and it only lasted a week before the jets went out. I got rid of the original carb because I got rid of the stepper motor wires during my rebuild. And the mechanical fuel pump went out on me a couple weeks back and I replaced it with an electric pump.
post #5 of 8 Old 05-12-2014, 10:56 PM
Caboose89
Make sure all the gauges work. Lights and what not. Check for leaks. Be sure to crawl under and check the frame for rust along with your floor boards. Jeep heaters are amazing so if it's working there's no problem keeping warm. Take a look under the dash and see what kind of mess your wiring is in. Make sure the 4WD works and Check the ebrake. The 4.2 and 2.5 are good engines. Treat them right and they will return the favor. Don't set your standards too high. It's not going to ride like your old Cherokee.
post #6 of 8 Old 05-14-2014, 07:48 AM
WDNewman
Rust rust and more rust. This one has the ole "rust cover" diamond plate over the rocker panels which is that many owners do to cover up rusted out tubs. The windshield frame looks to have been replaced also, another indicator of rust problems. Shame it has the carb instead of the fuel injection, but in compensation the hardtop looks good.
My '89 runs perfectly, and has since I bought it. It needed about $2k additional to the buying price to get the mechanicals sorted out and seats replaced,etc.
$3k (Canadian?) is a good price, but I couldn't make out the odo mileage.
The 19,000 kilometers listed in the owners ad is either a mistake or bogus.
Hey guys, there is NO SUCH THING as RPMS. There is NO "S" in RPM.
A little knowledge is a dangerous thing, but not nearly as much as ignorance.
WDNewman is offline
post #7 of 8 Old 05-14-2014, 05:13 PM
R U STUCK
And even more rust...
'04 TJ Rocky Mountain, 4" Fabtech, Sitting on 35"s
Jeep Selling Guru...
IG: R_U_STUCK
R U STUCK is offline
post #8 of 8 Old 05-15-2014, 06:21 AM
WDNewman
Yep, and long as the problem exist I will keep calling attention to it.
Go sell some cars.
WDNewman is offline
