#1 | ||
Lifting a 4 Banger
#2 |
i got a 3 inch bds lift with 33" toyos and 4.10 gears. it needs new gears, but i probably could have stuffed 35's under it with the lift.
#3 |
Junior Member
if you are just starting your build stop and get a 4.0 i wish i did every day if not dont go over 35s
#4 |
u need to rear gear the biggest tire on a four banger i would go is 35s
94yj-2.5-2inch bl-1inch shackles-4inch RC lift-Aussie locked front-8.8 limited slip-kc lights-4:88's-33 baja-rhino lined tub.61cj-5-current restoration |
#5 |
Junior Member
and lift hight 3" is good for 35s 4" is as high as i would go no need for anything more
#6 |
Just started looking.Coming across a lot of 4 cyl at a good price. The 4.0 seems to be made of gold or something. I would like to put a 6-8 inch lift with 36's or even 38's.
#7 |
Just Another Jeep Junkie.
It's funny how the first thing out of a lot of people's mouths is "go buy a 4.0..."
It's your jeep, go as big as you want, 4 cyl or not. Just remember that you'll have to regear, and get used to the right lane on the highway. I drive a 4 cyl, and after having several 4.0l jeeps, I don't mind it. I mean, sure, you have to be heavy on the throttle sometimes, but it gets the job done.
I'm right 97% of the time. Who cares about the other 4%? 97 TJ 2.5l/ax-5 - 3 inch bb, 31x10.5 Adventuro MT's |
#8 |
not your average SE
Biggest I saw was a YJ 2.5 running 37 TSL's on Wagoneer Dana 44's with 5.13 gearing.
98 TJ - 2.5L Low Output, RE BB+1BL 32X10.5 TSL Radials, HF REW8000# Winch, LoD Swingout, hacked front bumper, Savvy Gas Skid (love it), Aussie Locked 30, Dana 44 Chromoly (Detroit locked) Build Tread ~~~~~~~~~~ 99 XJ Stock NP231, 8.25 00 XJ Stock "Dark Blue" NP242, 8.25, 0331 Victim "He who does not pass the meatballs is not my friend." --Old Swedish Proverb |
#9 |
JF is my second home.
When you get above 35s you have to start changing axles out which if this is a trail only rig a 4cyl could be do able with steep gears and large tires, if this is your DD the biggest I would go with a 4cyl is 31s and 33s with a regear to 4.88. Also once you go to 35s or larger you should start looking at other things like steering upgrades and brakes. If you have choice I would get the I6, beyond the better motor you might also get one with a rear D44.
Max 2003 Jeep Wrangler Rubicon 4.0L, 42RLE, Dual Tops, Full Doors, Front Discos, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 5.25" Speakers, 6.5" Infinity Component Speakers. |
#10 |
very true dont get impatient when it comes to buying a jeep go 6cyl you can find a deal you may just have too look a little longer. i have had 2 4cyl they suck!! i sold them the engine sucked so bad.
insert stuff here |
#11 | |
insert stuff here |
#12 |
Junior Member
I havent even lifted my 2.5L yet and I'm suffering with 31's. I drive 30 minutes on the highway to get to work durring rush hour. Maybe that has something to do with it. lol
The 4.0 is a great motor, but if you realy fee like modding your 4 cylinder, go for it. It will have all the power you need off-road.
1997 Jeep wrangler 2.5l I4- Some cheap stuff to get it farther (only on 31's) 1994 Cherokee sport- Nothing yet but 235 All-terrains, Borla cat-back, and rusted out floor boards. "Never take life seriously. No one gets out alive anyways"-Anonymous |
#13 |
Tire size really does'nt matter as long as you change the gears. Back in the day a buddy of mine had a four cylinder with 18/39 Mickey Thompson's on his truck with 5:13 gears. I ran like it had stock tires on it. We did'nt do any off roading with it though, he and I were in to the show truck scene. On raod at highway speeds,it did fine. It tach'd around 3,000 with stock tires on it,so keep that in mind as well. Just my 2 cents worth.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| 4 banger tj | victory red | Jeep Buying Forum | 4 | 11-30-2008 06:47 PM |
The time now is 08:33 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
