Info on Possibly buying a 1998 Grand Cherokee - JeepForum.com
post #1 of 6 Old 05-15-2014, 01:07 PM Thread Starter
dunejeeper
I'm going to take a look at this in about 30 minutes. What should I be mindful of? I know more about Wranglers and next to nothing about GC. Are there any red flags I should look for? I'm basically going to use it as a winter driver and maybe light trails.
http://muskegon.craigslist.org/cto/4470299925.html
dunejeeper is offline
post #2 of 6 Old 05-15-2014, 03:03 PM Thread Starter
dunejeeper
I went to look at it and I test drove it. The only thing I noticed wrong is a clicking coming from what sounds like the front drivers side wheel/axle area while engaged in 4wd. The clicking is more frequent while turning. Is this likely an axle u-joint? If so, what does that cost to fix. I will likely try my hand at fixing it.
post #3 of 6 Old 05-17-2014, 06:10 AM
R U STUCK
If it is a u-joint. It's a $10 part...
'04 TJ Rocky Mountain, 4" Fabtech, Sitting on 35"s
Jeep Selling Guru...
IG: R_U_STUCK
R U STUCK is offline
post #4 of 6 Old 05-17-2014, 09:53 AM Thread Starter
dunejeeper
It looks and sounds like it's going to need u joints for the axles, upper and lower ball joints, and a chain in the transfer case. I haven't priced these parts yet, but I'm thinking I can do the repairs myself. Is $500 worth of parts a fair estimate?
post #5 of 6 Old 02-11-2015, 10:34 AM
heapster
1983 CJ7
So did you buy the Grand or not? Enquiring minds want to know. If you are still looking for one get in touch with me through Dave (DG6772) I can help you check them out if its a 96-98
Doug
98 ZJ Limited- 5-niner 97 ZJ Limited
96 ZJ Laredo 89 XJ Laredo
83 CJ project
heapster is offline
post #6 of 6 Old 02-11-2015, 07:18 PM Thread Starter
dunejeeper
No I didn't end up getting the GC. I ended up getting a 98 Chevy Tahoe for $1500.
