Help Me decide between this YJ and CJ - JeepForum.com
post #1 of 11 Old 09-27-2013, 07:31 AM Thread Starter
Grims
1983 CJ7
I started looking for a CJ, because I love the look of that model (especially the dash). A friend of mine mentioned a YJ can be rather easily converted so I started looking into them as well.
The Jeep will be driven daily to work, but it is only a 5 miles commute. However it needs to be able to travel to wheeling destination on the highway, which is a minimum of a 300 mile drive.
Here my two strongest picks.
1985 Jeep CJ7
http://sanantonio.craigslist.org/cto/4059678509.html
I have verified there is no frame rust on the CJ7, which a Jeep friend of mine says must be an act of God. the motor and tranny were rebuilt with the Clifford 6=8 setup and then only driven about 12k miles. Gears seem a little much for those tires, but I'd plan to go to 35s at some point which should help compensate some. Tub has two small rust areas under the Jeep insignia on each side.
1995 Jeep YJ
http://austin.craigslist.org/cto/3973992686.html
the YJ has a hard top and AC which i would put in the CJ before next summer. (Sorry guys, but I'm not tough enough for Houston traffic at 110 degrees) It has the 4.0 Straight 6, the ad says V6 by mistake.
He also texted me this additional info on it.
+XXXXXXXXXXX: 5 speed stock Tcase with SYE kit Rubicon axles w/factory air lockers, 4.10 gears Alloy USA chromoly axle shafts front and rear Rockcrusher dif covers, 8:07 AM
+XXXXXXXXXXX: ORFab full cage, upgraded crossover steering, Dwayne disconnects Poison spyder rock sliders 8kike milemarker, swing out tire/gas carrier, bombproof 1" 8:07 AM
+XXXXXXXXXXX: lift motor mounts, cobra cb in security box mounted to cage, kc dayligters, smitty tube fenders, pioneer cd/radio, Bedliner inside Good ac/heat, new hy 8:08 AM
+XXXXXXXXXXX: draulics for clutch
Grims is offline
post #2 of 11 Old 09-27-2013, 09:20 AM
Duck Doctor
The YJ is the better deal. Carbs are a pain to deal with in off road rigs so I'd pass on the CJ...especially at that price.
The YJ appears to have been thoroughly abused. I would honestly pass on both and keep looking.
Have you considered a TJ? I've owned a CJ7,YJ, and three TJs over the past 20 years. The TJ is a superior vehicle. You can buy a comparably equipped TJ for the same price as those two rigs you posted.
Duck Doctor is offline
post #3 of 11 Old 09-27-2013, 09:28 AM Thread Starter
Grims
1983 CJ7
The TJ is an undeniably superior platform, but I don't want a TJ. I want something dead simple to work on, and the looks of a classic Jeep. I can't stand the plastic interior of the TJ & JKs. I worked the price down some on both of these listings, and they each have thousands of dollars in mods I would end up doing anyway.
Grims is offline
post #4 of 11 Old 09-27-2013, 09:30 AM
Adam013085
Both rigs are way overpriced. For $11k you should be getting a completely restored CJ. Same goes with the YJ, for that price dont take someone elses project hackjob over.
Adam013085 is offline
post #5 of 11 Old 09-27-2013, 09:34 AM Thread Starter
Grims
1983 CJ7
It's possible the market is different in your areas. Both of these are priced fairly well for Jeeps with these modifications in this area.
Grims is offline
post #6 of 11 Old 09-27-2013, 09:38 AM
Adam013085
If time permits why not fly elsewhere and save a few thousand? I know this is not an option for everyone. It wasn't for me when I was looking.
post #7 of 11 Old 09-27-2013, 09:40 AM Thread Starter
Grims
1983 CJ7
I'd consider it if it was still a significant savings after taking into account airline tickets, and a potential cross country trip. So far I haven't found anything that would be worth it in the end...but if anyone has any suggestions I'm up to it.
Grims is offline
post #8 of 11 Old 09-27-2013, 09:41 AM
Adam013085
You can find CJs in that shape priced 4-5k less around where I live and they are priced high here too judging by what others say on this forum. The YJ you could probably find about at half that price too.
post #9 of 11 Old 09-29-2013, 05:35 AM
WDNewman
AMEN!!
Expand your search. Any Jeep in the deep south should be rust free if it was not "imported" from the land of salt roads. The YJ is a MUCH better platform than the CJ. Either way try to find a completely stock unit. Buying some other guys idea of what a Jeep should be can be a crap shoot. If you must modify, do it yourself and save yourself the hassle of trying to re-do mistakes and stupid ideas. Also, half the fun of owning a Jeep (a real one) is working on it, which is a good thing, because you are going to be spending about half of your time doing exactly that.
Amazingly, prices seem to rise as deer season approaches.
WDNewman is offline
post #10 of 11 Old 09-29-2013, 06:05 PM
YJjeeper90
Originally Posted by Grims
I started looking for a CJ, because I love the look of that model (especially the dash). A friend of mine mentioned a YJ can be rather easily converted so I started looking into them as well. The Jeep will be driven daily to work, but it is only a 5 miles commute. However it needs to be able to travel to wheeling destination on the highway, which is a minimum of a 300 mile drive. Here my two strongest picks. 1985 Jeep CJ7 http://sanantonio.craigslist.org/cto/4059678509.html I have verified there is no frame rust on the CJ7, which a Jeep friend of mine says must be an act of God. the motor and tranny were rebuilt with the Clifford 6=8 setup and then only driven about 12k miles. Gears seem a little much for those tires, but I'd plan to go to 35s at some point which should help compensate some. Tub has two small rust areas under the Jeep insignia on each side. 1995 Jeep YJ http://austin.craigslist.org/cto/3973992686.html the YJ has a hard top and AC which i would put in the CJ before next summer. (Sorry guys, but I'm not tough enough for Houston traffic at 110 degrees) It has the 4.0 Straight 6, the ad says V6 by mistake. He also texted me this additional info on it.
I have a 1990 YJ an I love it
Being fuel injected I would go with the YJ
Also 1994-95 YJs have galvanized tubs witch means no rust!
YJjeeper90 is offline
post #11 of 11 Old 09-29-2013, 06:10 PM
Adam013085
94-95 may have galvanized tubs, but tub rust is easy to spot. Its the frame rot and everywhere else that can be tricky to spot
