Early 70's Jeep - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Buying Forum > Early 70's Jeep
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 10-13-2008, 05:50 PM   #1
Keestan31
Early 70's Jeep
I have never owned a Jeep but I have been looking for a project and I found a Jeep the owner says is between a 68-70 jeep, has a 304 v8, he doesn't know much else about it because he got it when his uncle died...it runs, body is in decent shape, 4x4 works, but it needs a new clutch...he is asking $350 I was just wondering if you could give me a little more info on how these jeeps are what type of drivetrain they came with, what axles they came with...or any other valuable info I may need....there is not title but it is just going to be an offroad project anyways
Keestan31 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 01:52 AM   #2
Mickey_D
Sounds like a CJ-5. The clutch is easy with a standard tool box. Drop the driveshafts, unbolt the tranny and transfer case as one from the engine, pull the tranny back to expose the clutch. If the flywheel looks okay, replace the clutch, throwout bearing (and pilot bearing if it has it, I'm used to the 258 so have no idea), and pressure plate. Put the tranny back on and hook up the driveshafts.
There are some other things you'd need to do such as pulling the shifter mechanisms and clutch release mechanism, but a Chilton's or Hayne's manual will do you wonders.
I would venture that the 304 alone (if it runs) is worth the $350 he's asking. If the tub is intact it's CERTAINLY worth that and more. Check this thread for what I mean. If I lived closer I'd be chomping at the bit to buy it out from under you!!
As for what they ran for driveline components, they were as varied as they come. My 74 had a 258 I-6 with a 3 speed and a 5 position transfer case (4Hi-2Hi-N-2Lo-4Lo) which I found unique. As far as I know they came with 3spd, 4spd and 5spd manuals and 3spd autos. They also came with 151 I-4's, s different I-6's and two different V-8's. The axles were just as varied as well. There were also short and long wheelbase chassis. Buying a CJ is like getting a Christmas present. You can own it for a couple years and still be finding stuff out about that you never knew.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
Mickey_D is offline   Reply With Quote Quick reply to this message
