Can I fit 35's? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Buying Forum > Can I fit 35's?
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 08-20-2009, 05:51 PM   #1
Thisisaustin
Can I fit 35's?
sorry, i didnt know how to delete the thread =/ sorrry!
Thisisaustin is offline   Reply With Quote
Unread 08-20-2009, 06:08 PM   #2
alecmcmahon
35's will prob. fit just fine
but
you'll come into issues where you'll want to re-gear the axle ( you'll experience a big power loss )
and if your doing any wheeling, you'll want to either make sure it comes with a dana 44 rear axle, which is much stronger then the stock dana 35 rear axle.
and whats with that winch cable?
-my build thread-
alecmcmahon is offline   Reply With Quote
Unread 08-20-2009, 06:21 PM   #3
Thisisaustin
yea i plan on checing on the axle.
i think it'll still be pretty powerful with the 35's
Unread 08-20-2009, 09:49 PM   #4
RogueSpear2023
It's a JK they all came with D44 rears, actually they are even a stronger D44 than found in a TJ. I think some are calling them a D47 or something like that. But you may want to regear as you are going experience a power loss, maybe look at 34s split the difference. Or drive it and see, you could always remove the lift, I think JKs can run 33s without a lift. Honestly it doesn't look bad with 33s you will have room for flex this way. I maybe is an inch high, but that would be it. It looks better than a 4" lift on a TJ with 31s.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Unread 08-21-2009, 10:18 PM   #5
Thisisaustin
So if i size up to 35's i'll need to re gear, correct?
what if I keep it with the 33's? will I still need to re gear to get the most power out of the vehicle???
