Buying my first XJ! - JeepForum.com
post #1 of 3 Old 07-12-2011, 04:50 PM Thread Starter
on_holidays
Buying my first XJ!
I'm finally ready to buy my first Cherokee & I've narrowed it down to two. One is a '99, classic sport w/ 126k. 6-cylinder, tinted windows, & very stock. Dealership is asking $3995.
The other is a 2001, has a 3in lift kit (which I would be adding to the other Jeep anyway), 150k, clean title. I'm still waiting to get more information, as of now I don't know if it's a 4 or 6-cyl. The owner is asking $4k.
So I'd like to know, is there a significant difference between the '99 & '01 models? Is one known to be better than the other? & what should I look for, as far as potential problems each might have. Common spots for rust, brake issues, etc.
I've been searching for the right Cherokee for months, so I really hope one of these two works out.
Thanks for your help!
on_holidays is offline
post #2 of 3 Old 07-17-2011, 08:52 AM
rsurran
2001 Possible Head Issue
I have 2000 XJ which has the 0331 head. The forums are full of posts on these heads that came on 00 and 01 XJ's. If I had it to do over I would go with another year XJ. Most guys think the 98 XJ was a pretty good year. Check the 2001 to see if it has 0331 head or some other. Look on the manifold side of the head for the head number.
rsurran is offline
post #3 of 3 Old 07-17-2011, 07:33 PM
silver60th
The 2001 will have the 0331 head unless it has already cracked and been replaced. However, the chances of the head cracking aren't as great as Jeepforum makes them out to be. Make sure that the cooling system is kept up to par and the jeep doesn't overheat, and you should be golden.
Now, that being said...the 2001 Jeeps have some peculiarities that should be noted.
2001:
Coil rail instead of distributor
Low pinion D30 instead of high pinion
Very small chance of 0331 crack
Misfire on cylinder 3 code is thrown on heat soak due to faulty injector shielding (if not corrected)
I would suggest the 1998. And that's coming from someone who owns a 2001. The 98 will have the slightly stronger HP D30 and no 0331 casting. Simply put, they seem to be more durable and easier to work on.
Plus, don't know how you feel about someone else's junk, but I don't like Jeeps that come with lift kits. It's hit or miss on who installed it, what kit it is, how it's aging....I would much rather deal with my own stuff.
Life is life and fun is fun, but it's all so quiet when the goldfish die.
2001 XJ 4dr, 3'' lift, LP D30 & Ford 8.8 w/limited slip, 4.10's
Front OEM skid and rear gas tank skid, rock rails
silver60th is offline
1999 , 2001 , cherokee
Buying an LJ BigFootJim Jeep Buying Forum 3 11-22-2010 10:46 AM
Considering buying a '93 YJ md93yj Jeep Buying Forum 1 10-01-2010 07:24 PM
If you were buying an XJ GT2XJ Jeep Buying Forum 0 09-26-2009 06:42 PM
help Buying a ZJ or a WJ. snobum181 Jeep Buying Forum 2 09-07-2009 07:19 PM
Help on buying. Gagt518 Jeep Buying Forum 5 08-13-2009 08:33 PM
