Advice on first wrangler purchase - JeepForum.com
post #1 of 5 Old 05-10-2014, 12:17 AM Thread Starter
sbollin
Tomorrow I'm going to check out two wrangler's. This would be my first time purchasing a jeep. I've been driving Saab's for the past couple years and am quite tired of their expensive problems. Always wanted a wrangler now I finally have a little saved up for a used one. There are two at a dealership here. Any advice on what I should look for. And are these a fair asking price.Thanks in advance. Here are the links for the two. http://www.abwautos.com/2005-Jeep-Wr...-06770/5031872
http://www.abwautos.com/2006-Jeep-Wr...-06770/4980718
sbollin is offline
post #2 of 5 Old 05-10-2014, 07:26 AM
WDNewman
On the 2005 the only red flag that I can see is the diamond plate rust covers on the front and rear corners. I would check very very carefully underneath for both frame and tub rust, which is the killer of jeeps, especially in your part of the world. Neither jeep looks to be modded to death, which is a big plus. However just by looking at the pictures the 2006 would be the one I would be interested in. No obvious rust cover up. Stock as far as I can see which is a big plus. A more basic model, with fewer miles. Do a Carfax check on the one you decide on, as well as a very through rust inspection. Keep us posted on how you come out.
Hey guys, there is NO SUCH THING as RPMS. There is NO "S" in RPM.
A little knowledge is a dangerous thing, but not nearly as much as ignorance.
WDNewman is offline
post #3 of 5 Old 05-10-2014, 07:41 AM Thread Starter
sbollin
Great thanks. Yeah I've read about rust problems that'll be the first thing I check. Didn't realize the plate covers were to hide rust. Figured that was for styling.
sbollin is offline
post #4 of 5 Old 05-10-2014, 08:42 AM
222Doc
222Doc's Avatar
unless you can turn a wrench. A jeep is rather expensive to repair as well and drive. As much as people want a Jeep, does want justify the need.
Rust that you see is not were you need to look. Frame and tube to frame as well as just what you see, the panels. as much as 4.0 is well known to have a long life. Miles are miles on anything.
222Doc is online now
post #5 of 5 Old 05-10-2014, 11:43 AM Thread Starter
sbollin
Decided on the 05. Checked for rust and the bottom was pretty much rust free and very clean. Looked under the faux diamond plating and there was no rust either. The adhesive was loose so I peeled it away. Very good power while on the test drive and nothing out of the ordinary that i could tell from the short drive. I have 30 days if any problems should arise. As far as expensive repairs, I've always fixed my own vehicles so I'm mechanically inclined somewhat 😉 I have 4 Saab's I'm always getting some random code thrown or odd noise, I'm forever fixing something. But from the looks of it at least everything in the engine bay seems more accessible then the super tight saab engines. I have to be a hand contortionist to get anything done. Picking it up Monday. Winters should be a lot easier to navigate now.
sbollin is offline
