??? about which 4x4 system jeep has - JeepForum.com
post #1 of 7 Old 03-31-2010, 04:52 AM Thread Starter
monkers
2010 JK Wrangler
im new to jeeps and have another question, ive been told that jeep has about 4 different 4x4 systems, is that true, and how do you tell which the vehicle has? Someone said there is a sticker in the glovebox with a code, where would i cross reference that code? Which 4x4 systems if any, should be avoided? Thanks for all the help
Craig
monkers is offline
post #2 of 7 Old 03-31-2010, 05:09 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
None of the Jeep 4X4 systems, when properly maintained, are worse than others.
There are two basic systems and then some minor changes in rigs with those systems.
What model are you looking to get, age of rigs you are looking at????
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 7 Old 03-31-2010, 05:21 AM
rustywrangler
It really depends on the years you are looking for. There will be either a part time/full time, part time, or full time t case setup.
Just about every Wrangler is going to be part time 4WD and then add in vac disconnects in the front for older models.
Grand Cherokee's have alot of the full time transfer cases.
I could go on and on, it helps to know what rigs you are looking at, year range etc.
post #4 of 7 Old 03-31-2010, 06:00 AM Thread Starter
monkers
2010 JK Wrangler
not sure what im looking for just yet, found some older (88-90) wranglers, but have also contemplated new, the (sport, then add tires and wheels to it) the used prices im finding are pretty steep for newer jeeps, still looking and researching what i want. thank you guys for all the help, im new to all this
monkers is offline
post #5 of 7 Old 03-31-2010, 06:08 AM
rustywrangler
Ok, sounds like you are looking at wranglers. For the most part you are looking at the same 4wd system in all of them.
87-95 (YJ Model) will be a 2high, 4high N 4Low shifter in the cab. Along with a vac disconnect front axle.
97-06 (TJ Model) will be a 2High, 4High N 4Low as well but a sold shaft in the front axle, no disconnect.
post #6 of 7 Old 03-31-2010, 12:40 PM Thread Starter
monkers
2010 JK Wrangler
thanks guys, im sure ill have a million more questions.............
monkers is offline
post #7 of 7 Old 04-02-2010, 01:49 AM
RogueSpear2023
Yes wranglers have a similar if not the same transfer cases for almost all YJs and TJs, 07+ JKs now have a little larger t-case, but still similar in design. They are going to part time transfer cases, this is preferred for the most part if you are planning on off roading often
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
Should I take advantage of this Jeep? (1994 Jeep Wrangler Sahara)?? JPJEEP18 Jeep Buying Forum 10 05-07-2009 02:23 PM
First Jeep Need Opinions 1975 Jeep CJ5 Pic's Listed FastGM400 Jeep Buying Forum 4 12-03-2008 07:00 PM
