4 vs. 6 cylinder wrangler? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Buying Forum > 4 vs. 6 cylinder wrangler?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 03-26-2010, 12:29 PM   #1
peregrinefalcon
First off, I've never owned a wrangler, but have wanted one for 20 years. Looking for:
5 speed
6 cylinder
full hard doors
$5-10K
'98-'04
Use: as a second vehicle to cruise around with on the streets, *maybe* a little light off-roading. I've heard that 4 cylinders (the SEs) just do not have the power one would want. As a second vehicle, non-speedy, lady driver, but one who wants the capability to handle just about any condition, is it worth saving the money at the sacrifice of the power? As for many, money is tight and getting one at all would be a splurge. All the ones I have seen that are in the right price ranges are 4.0s. Thanks.
peregrinefalcon is offline   Reply With Quote
Unread 03-26-2010, 12:36 PM   #2
bcochran
In my few months doing some research, the 4.0 6 cylinder is the engine of choice. The 2.5 is not a powerful engine, and therefore keeps your rpms up and your mileage down. That said, I don't think the 4.0 is much better fuel wise, however, it can get out of its own way...
bcochran is offline   Reply With Quote
Unread 03-26-2010, 12:44 PM   #3
minimodes89
minimodes89's Avatar
Originally Posted by peregrinefalcon View Post
$5-10K
you should be able to find plenty of 6's to choose from in that range. Besides its better to get what you want instead of just getting something because its cheaper and then regretting it.
Do you mean the ones in that price range are 4 cylinders? Because the 4.0's are the 6 cylinder, so that wouldn't be a problem
98 Jeep Grand Cherokee Limited-Stock 121000 On the clock
Penn State Alum:Industrial Engineering
minimodes89 is offline   Reply With Quote
Unread 03-26-2010, 01:42 PM   #4
Pallando
The 2.5l gets better gas mileage. Read any of the MPG threads on this forum, people with the 2.5l engines are consistantly the ones getting 2-3 mpg more then those with the 4.0.
For cruising around town, and light highway traveling, the my 2.5l does fine. In terms of offroad, neither is better then the other, you wont miss the power at all. Though the 2.5l again gets slightly better gas mileage even offroad.
It has weak acceleration, but people seem to overplay this aspect of it. It does fine merging onto highways if you know how to drive at all.
the greatest benefit to getting a 2.5l, however, is you can consistently find them 2k$-3k$ less then 4.0l's with similar years and mileage.
Pallando is offline   Reply With Quote
Unread 03-26-2010, 01:49 PM   #5
xxxflhrci
Nearly all 4 banger owners wish they had gotten the 6. Very few, if any 6 cylinder owners, wish they had gotten a 4. There is a reason for this.
xxxflhrci is offline   Reply With Quote
Unread 03-26-2010, 01:55 PM   #6
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Ahhh, the classic 4 vrs. 6 debate... its never ending.
I own a 4-cyl, and although Id like a 6-cyl, in this part of the country, they are twice as much...
With that being said, I love my 4-cyl. If you are only using it for weekend wheeling around town, Id say go with the 4-cyl, you will spend SIGNIFIGANTLY less than a 6-cyl, especially if this is a "splurge" purchase. Its really not THAT bad...
4-cyl come with factory 4.10 gearing... most 6-cyl come with a 3.73 or higher gear ratio, unless you get a Rubicon... so IMO, youll get similar performance between the two engines unless you regear...
Thats what I got for ya...
-Dave
Shameless plug: www.davidisabeersnob.com
My CJ7 Build Thread
AustinCJer is offline   Reply With Quote
Unread 03-27-2010, 01:31 AM   #7
RogueSpear2023
Well actually from searching the mileage difference is less than 1 mpg, and once you go to larger tires like for off roading that 1mpg you get better is now worse than the 6cyl with the same tires. A 6cyl is worth the wait. Especially considering the price difference is only a thousand or two more, for around town a 4cyl will be fine, but if you go the hwy you will regret the 4cyl. Off road it doesn't make much difference.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
TJ Tech Boot Camp
TJ Specs
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline   Reply With Quote
Unread 03-27-2010, 02:02 AM   #8
moonshinefuel
I would narrow my search a little more to 2000-2004 Wrsngler 6 cylinder. Most all in these years came with the burly NV3550 transmission. It has a lower first gear ratio and higher torque rating than the ax 15 transmission. The 4 cylinder wranglers would not have been so bad if they came with a factory ax 15 behind them, but they don't. They all come factory with the ever problematic ax 5.
moonshinefuel is offline   Reply With Quote
Unread 03-27-2010, 08:07 AM   #9
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Is this true for automatics? Because I have a 2004 standard 4-cyl with the nv1500...
-Dave
My CJ7 Build Thread
4.0 , 6.0 , wrangler , wrangler se
