Defective Superior D44 Axle - JeepForum.com
post #1 of 15 Old 04-08-2010, 06:54 PM Thread Starter
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Heard mostly good about Superior so this isn't intended to be a bashing thread just looking for opinions on this break. This axle had 40 miles of wifey driving time on it is all. She drove it to her girlfriends house all paved city roads. While backing out of the driveway she heard a clunk and thought she might have ranover a bicycle or something. So she got out and didn't find anything and got back in to head home. The Jeep wouldn't move at all in forward/reverse or FWD (hubs weren't locked in) When I got there I checked the tranny fluid and then the linkage. While checking the linkage I noticed the rear wheel tilted in slightly. Broken axle! I locked the hubs in, put it in 4WD and parked it. Here's what I found.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #2 of 15 Old 04-09-2010, 02:03 PM
austentatious
Thats INSANE. Sue the company
O|||||||O
|ProComp|Rokmen|Zone|MetalCloak|RockHard|Mastercra ft|TomWoods|Novak|TenFactory|Synergy|
austentatious is offline
post #3 of 15 Old 04-09-2010, 02:44 PM
ajmorell
ajmorell's Avatar
There certainly looks like something was with that axle shaft. Have you contacted Superior yet?
I think that's a little overkill
ajmorell is offline
post #4 of 15 Old 04-09-2010, 03:27 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
that is a defective part, contact superior with these pics. you can see, maybe only 1/4 of the actual material was there and holding asn is a clean break. the other looks like maybe some sort of air was trapped or an area of weaker material trapped there.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #5 of 15 Old 04-09-2010, 06:14 PM Thread Starter
Reelm n Rubi
Fish fear me
Quadratec and Superior Axle have been excellant to deal with with this problem. They're sending me replacements with bearings and wheel studs already pressed in on a Redeye flight to me. They've never seen a break like this and want to examine it to determine the problem.
505 Performance PCM
post #6 of 15 Old 04-14-2010, 12:28 PM
alex211
1995 XJ Cherokee
Your mentality is killing our country.
95 xj bone stock for now
alex211 is offline
post #7 of 15 Old 04-15-2010, 12:00 AM
tjwoo
tjwoo's Avatar
/facepalm
I'm glad superior is standing behind their products and redeye delivery of replacement parts is outstanding customer service.
tjwoo is offline
post #8 of 15 Old 04-15-2010, 05:25 PM
colojeepguy
1970 CJ5
X2. No one was hurt.(luckily!) Sounds like the company is bending over backwards to make the problem right. Why sue?
colojeepguy is offline
post #9 of 15 Old 04-15-2010, 05:34 PM
USAFRecon
It's people like you that just make America great
USAFRecon is offline
post #10 of 15 Old 04-15-2010, 05:43 PM
jtpaintball70
jtpaintball70's Avatar
Never seen one break like that. Glad that they're taking care of you though and no one was hurt
Nathan
KD5QHI
NREMT-I/85
jtpaintball70 is offline
post #11 of 15 Old 04-15-2010, 06:50 PM
austentatious
Guys it was a joke! I was just trying to express how extreme of a break that was. Sorry for offending. I would never do that!
O|||||||O
post #12 of 15 Old 05-09-2010, 08:24 PM
csouers
Wow. Think if that would have let go on the highway.
Glad it didn't or you'd have one messed up wife.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #13 of 15 Old 05-10-2010, 06:46 AM
mcneil
So what's up with the ground down heads on the wheel studs? Did you have to do that or did they come like that?
mcneil is offline
post #14 of 15 Old 05-10-2010, 11:43 AM Thread Starter
Reelm n Rubi
Fish fear me
The wheel studs that came with the Superior axles were narrow head wheel studs but weren't long enough for my wheels. I had to grind about an 1/8th off the studs that I added to the axles so they wouldn't hit the parking brake assembly. I just went slow and moved from bolt to bolt so as not to heat stress the bolt. The new Superior axles came with pressed studs that were plenty long.
505 Performance PCM
post #15 of 15 Old 05-20-2010, 10:54 AM
BlackBellamy
BlackBellamy's Avatar
Well I didn't know it was a joke. It caused me mental anguish and I also can't have relations with my wife.
YOU WILL BE HEARING FROM MY ATTORNEY!
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
Defective Freeze Plug j_bydesign General Discussion 11 10-14-2009 02:05 PM
Metric system-Superior, why not change? cj847 General Discussion 49 11-20-2008 06:46 PM
Would you like some defective software with your fries? Fett General Discussion 7 08-15-2007 08:08 PM
got a drink bottle with a defective seal Matt Gertsch General Discussion 28 11-10-2006 09:16 AM
Superior shippnig issues? under_psi General Discussion 17 06-15-2005 11:50 PM
