Death of a Tire at 75mph - JeepForum.com
post #1 of 24 Old 07-20-2008, 09:23 AM Thread Starter
tjwoo
tjwoo's Avatar
I was traveling down the highway passing another vehicle on the first lane. As i was going down, i felt the jeep pulling to the right very slightly, and at first I put the feeling off as me overreacting over something or it was just the road being a little rough. Shortly after, the driver side rear tire exploded, enough to scare the bejesus out of me and my passengers in the jeep and surely the people following me.
I was going around 75mph at the time, but I fortunately never lost control of my jeep, and quickly managed to move into the left shoulder. Full size MATCHING spare was a savior, and also i happened to be carrying my floor jack in the back of my trunk from helping a friend out rotate his tires earlier in the week, so switching out the tire took less than 5 minutes.
Here is the carnage
The tire is 32" BFG AT KO
Question is, anyone have a guess why it happened? I regularly rotate, maintenance my tires, as well as checking tire pressure very regularly. The tire barely had 25k miles on it, and had significant amount of tread remaining
tjwoo is offline
post #2 of 24 Old 07-20-2008, 10:52 AM
havasu
On permanent vacation
havasu's Avatar
My guess is the tire lost all pressure, but because of the sidewall strength (and the light weight of the jeep), it didn't look flat. Once you got some speed going, along with the friction of the flat, the tire failed and separated at it's weakest point, being the sidewall. My wife did the exact same thing on her Toyota Avalon, and she told me her tire passed her on the freeway. The separating tire caused a considerable amount of damage to the fenderwell, so I filed a complaint with Michelin. They replaced my tire immediately for free, provided I sign off any damage the separating tire caused to the fenderwell. I believe it was just good business sense, because the tires only had 12,000 miles on them.
havasu is offline
post #3 of 24 Old 07-20-2008, 10:54 AM
Rico4x4
Wow! Glad you didnt lose control. Good job holding it steady.
Rico4x4 is offline
post #4 of 24 Old 07-20-2008, 11:02 AM
PILL
Remember guys, when a tire blows stay calm and smoothly pull over. If anything it is better to gas it than hit the brakes.
Nice job
Member 134 of the White Jeep Club
31" BFG A/T's, 130w KC Hilites
PILL is offline
post #5 of 24 Old 07-20-2008, 11:11 AM
jeepstronaut
1983 FSJ Cherokee
nice driving, now call the tire company and complain that the tread scratched your fender and now your wife refuses to ride with you...
you might just get some new rubber!
tHe Jeepstronaut
jeepstronaut is offline
post #6 of 24 Old 07-21-2008, 07:49 AM Thread Starter
tjwoo
tjwoo's Avatar
i figured out why my tire failed.
Where the valve stem meets the wheel, it is almost detached. I didn't mention that couple miles before this, I did come in very close contact with a runaway hubcap from another car infront of me, but i initially dismissed it for I thought I did not hit it. I did see it fly to the left of me. Well, I'm guessing it did indeed hit me on the tire and managed to take out the valve stem in a swift blow.
The tire blew about 2-3miles down the road after this incident and I def remember feeling the car pulling a little and a little squishy feeling on the rear tire.
The air was escaping at a alarming rate and eventually the sidewall just collapsed.
sorry for crappy phone pics
reason for failure. Fly hubcap that I thought I'd missed apparently did hit it. Critically. This caused my tire to lose all air and eventual sidewall failure
or maybe I really didn't hit the hubcap and the valve stem was just faulty. (really thought I cleared it)
pfft . http://www.wftv.com/news/16602114/detail.html
tjwoo is offline
post #7 of 24 Old 08-01-2008, 08:54 PM
ZeroGravity
Any idea what happened? YOUR TIRE EXPLODED!
I am glad you are alright. I would definately call the tire company and make sure there aren't any recalls or past problems with this tire.
ZeroGravity is offline
post #8 of 24 Old 08-18-2008, 12:56 PM
patricknolan
Nice job
Ummmm .... this doesnt sound right ....
Someone PM with why it is correct.
patricknolan is offline
post #9 of 24 Old 08-18-2008, 06:19 PM
till88
hey man depending on the place you got your tires... those valve stims look old!
You should go back to where you got the tires and say they didnt put new valve stims in and you blew a tire!
If you push hard enough they may replace it!! Or pro-rate it
I work at a tire shop and this happens everynow and then..
till88 is offline
post #10 of 24 Old 08-31-2008, 06:39 AM
Muddeprived
Muddeprived's Avatar
Here is the carnage
Glad you are ok.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #11 of 24 Old 09-01-2008, 12:51 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Did you run at speed on aired down tires after offroading much?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Jerry Bransford is offline
post #12 of 24 Old 09-03-2008, 10:24 PM
in_motion
damn. good thing i got MY leaky valvestem fixed! glad you're ok.
in_motion is offline
post #13 of 24 Old 09-14-2008, 04:42 PM
Greg_Volkman
same thing I was thinking. there is no damage to the rim or the innermost sidewall. It seems that the tire pulled apart right where the sidewall belts meet the tread belts. if he drove on it long enough while it was leaking air and running flat I would think there would be rim damage.
ALSO, I would not expect that they would have heard a LOUD bang if the tire was already empty (from the leaking valve) when the tread seperated.
I do not think this happened because of a leaking valve. i think the belts were weakened overtime and finally gave up the ghost.
I'd also like to note that anything that hit the valve hard enough to unseat it would surely have left a mark on the rim, and there doesn't appear to be one.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #14 of 24 Old 09-14-2008, 05:37 PM
heyitsme
i dont think this is the case. i've had a nail in one of mine before and it leaked down just a few pounds and i could tell a HUGE difference in handling, then i looked and saw that it was getting slack. i think this was a random sidewall failure.
heyitsme is offline
post #15 of 24 Old 09-17-2008, 12:57 PM
-Shoey-
2010 KK Liberty
Leaky valvestem....the reason why my WJ is sitting outside with a flat. Glad you're ok
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
Death Mask Grape Ape General Discussion 8 10-27-2009 08:29 AM
Would you want to know the day of your death? Chris_ General Discussion 23 04-08-2009 06:58 PM
Another hot car death... wow. JFamily General Discussion 15 09-06-2007 10:49 PM
Death of the SUV? matt_c General Discussion 34 09-14-2005 08:50 PM
H2 death spichman510 General Discussion 17 08-26-2003 08:18 AM
