how tough is uwharrie? - Page 2 - JeepForum.com
post #16 of 19 Old 10-10-2009, 03:16 PM
gharris54
you will be fine. I have a grand cherokee with a 3'' lift and 32'' mt's and I can do everything at ure no problem. Daniel is really not that bad, it took me like 3 tries to make it the first time I went when I was open and I locked the rear before I went last weekend and I just walked right up everything.
2000 dubya jay, IRO 3'' and 265/75R16 bighorns, quicker discos, custon spring retainers, custom ford 9'' rear end with the stock wj discs
Dana35 SOLID diff cover and a lock-right locker for a Dana35 for sale
gharris54 is offline
post #17 of 19 Old 10-13-2009, 05:57 PM
Mr. Corrosion
I drove Daniel on Saturday and found it a lot of fun, one of the best trails I've been on in the eastern US. I did use both lockers when I thought I'd need them and just walked right up everything without any fuss at all...but thats not to say it wasn't fun. I highly recommend Uwharrie to anyone wanting to go, I can't wait to go back.
2007 Rubicon 2-door, Red Rock
6-speed, Dual tops
2.5" Teraflex Coil Lift, Shrockworks Mid-Width, Warn M8000
Mr. Corrosion is offline
post #18 of 19 Old 10-18-2009, 02:38 PM
flatlander757
Uwharrie is a lot of fun, if you're on 33s you'll be perfectly fine.
Hell on 31s you won't have a problem with most of it. There are bypasses for all the hard parts so don't worry about it.
Here's a clip from Kodak Rock:
The easier side of Daniel:
This is the harder side of Daniel.. there are bypasses though so don't worry about it:
This is the same part of Daniel on a different trip, my friend Dave on 31s and nothing else:
Here is on the way to the big hill of Daniel:
You'll be fine.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #19 of 19 Old 10-21-2009, 04:17 PM
HolidayJeep
Want pie now.
HolidayJeep's Avatar
Some of our guys have done Daniel and Kodak with 31s and open axles, but took some damage. I've done all the trails including both sides of Daniel with 32s and a locked rear and have mashed my bumper, front diff, gas tank, and nerf bars.
There are a couple spots (Dutch John I think is one) where you can get close or scrape your driver's mirror on walls or trees.
Edit: if you go up Daniel from the parking lot side, there is no bypass and you'll need to climb two tough ledges.
Mike
Originally Posted by Slapahoe
Not to brag, I was the valid victorian my senior year. Best and the brightest of the bottom of the barrel.
Originally Posted by War Eagle
thunderspork
HolidayJeep is offline
Uwharrie NF 7/2-7/5 bebout North Carolina Jeep Forum 1 06-05-2012 10:49 PM
Uwharrie Nov. 7th?!? ABSOLUTCarCrazy North Carolina Jeep Forum 2 10-28-2009 08:37 PM
Uwharrie oct 9th brand0nlp South East USA 6 10-09-2009 05:58 AM
Uwharrie ok for a DD w/ a BB? NCJEEPFAN North Carolina Jeep Forum 8 03-08-2008 01:07 PM
UWHARRIE - Oct 26-27 Big-n-Broke-YJ North Carolina Jeep Forum 10 10-30-2007 08:35 AM
You may not post new threads
You may not post replies
