Wrench Fest - Page 9 - JeepForum.com
post #121 of 135 Old 10-09-2006, 11:19 AM
Cliff Crawler
Cliff Crawler's Avatar
Originally Posted by tommaho
Ok, then what Jerry B was thinking about in his post isn't happening - if your lower control arms are stock length then they arent pushing your axle too far forward. Since you mentioned your tires rubbing at full steering lock I think the best short term solution will be to fix that with washers behind your steering stops. That'll fix the tire rub and the tie rod won't touch the cover.
The long term fix will happen when you get adjustable control arms with your longarm kit. You can shorten your uppers to get caster back in spec and that'll rotate your axle rearward enough to clear if you decided to remove the washers.
Ah..ok, I was hoping there was a better solution than having to mess with the steering stops. ::sigh:: The long arm kit is looking better...and new wheels...and regearing....
Cliff Crawler : Jason
Email:
Rubi...or what's left of the stock parts.
Cliff Crawler is offline
post #122 of 135 Old 10-09-2006, 11:56 AM Thread Starter
XTC Jpr13
XTC Jpr13's Avatar
i had to adjust my steering stops as well. it does limit the turning radius a little, but not much that it is even noticeable. i would do that for now and then when you got long arm or even just adj, arms you can remove them, as long as you also fix the backspacing on the wheels. adjusting the steering stops should take you about 5 minutes(literally)
2010 Sponsors
XTC Jpr13 is offline
post #123 of 135 Old 10-09-2006, 07:51 PM
Cliff Crawler
Aww, sweet! I found a money tree in Nick's back yard!!! YES!
Email:
post #124 of 135 Old 10-10-2006, 02:23 PM
tommaho
tommaho's Avatar
Got my diff covers. These things are frickin hyooge.
Got the HP30 geared and installed. I need to replace the pinion seal (effed up and installed it before the oil slinger ) and align it, but other than that it's great.
tommaho is offline
post #125 of 135 Old 10-10-2006, 09:35 PM
jipjip
jipjip's Avatar
tom, we're gonna have to talk at the campsite. i am very interested to know how the install went, and how you did it. i know the basic concept of how to do it. but some experienced words always help. especially when your running the exact same axles as me
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #126 of 135 Old 10-11-2006, 05:20 AM
tommaho
tommaho's Avatar
Yeah man it's an easy job with all the right tools, just not for the impatient.
I'd been trying to use a regular bearing separator to pull the D30 carrier bearings and it turned out to be a really lousy way to do it, I still ended up grinding off the old ones. There are notches on the factory 8.8 carrier that let you use a 2 jaw puller and that one is a piece of cake.
When you do yours I'll lend you my setup bearings, that way it won't matter if you trash the old ones and you won't have to buy them or take the time to make them.
tommaho is offline
post #127 of 135 Old 10-11-2006, 06:37 AM
Cliff Crawler
My Ricoche Rockers just came in! YES!
Email:
post #128 of 135 Old 10-11-2006, 06:24 PM
jipjip
jipjip's Avatar
thanx tom, hopefully i'll be re-gearing to 4.88s next springs after my 35's go on.
jipjip is offline
post #129 of 135 Old 10-11-2006, 08:17 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Well - here is what has been accomplished:
1.) AirFlow Snorkle is installed. Airbox is completely waterproof, all the way down to RTV'ing the lid on...
2.) Gas Tank Skid and hidden hitch modded with a 20lb sledge to work together.. now they are installed..
3.) Fender Trimming is finished. No more bent fenders I hope!
4.) New Front Driveshaft is installed.
5.) Lots of fuse replacements and some wiring fixes
6.) 4.56's and rear ARB go in Monday... yay!!!!
SO little time before this run!!!!
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #130 of 135 Old 10-11-2006, 09:14 PM
jipjip
jipjip's Avatar
holy shnykies!!!, it looks like your all modded out for this trip!!!
maybe you can tackle the frog hole w/ all that waterproofing
now i'm jealous of you w/ your darn selectable arb's and stuff
jipjip is offline
post #131 of 135 Old 10-11-2006, 09:43 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Anyone who wants to see the snorkle... bad pics cause it's dark, but I just found my camera.. They aren't resized, so I won't direct link.
http://www.bethanybytes.com/kyle/jeep/exterior/snorkle/
- Chopped / Locked
- Daily Driver
post #132 of 135 Old 10-15-2006, 07:50 PM
tommaho
tommaho's Avatar
Just when you think you're done spending $$ on your rig for the year, neZZr puts his rockers up for sale and TJ on the Rocks posts a snorkle.
I guess even when you think you're done spending, you're not done spending.
tommaho is offline
post #133 of 135 Old 10-15-2006, 07:52 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I can't believe the response I got on those in such a short time! You're lucky you saw them when you did!
Now if only I could find a good deal on a hard top
I'll be Savvy someday!
neZZr is offline
post #134 of 135 Old 10-15-2006, 07:55 PM
tommaho
tommaho's Avatar
Haha, I know. Jamie found them and was like: ooh! ooh! neZZr! rockers!
Like two weeks ago I decided against spending almost $500 on rokmens with plates and gaskets.
tommaho is offline
post #135 of 135 Old 10-15-2006, 08:39 PM
gmcz7198ba
So can I take hostage pics for you now!!
Atleast they will be out of my garage, finally!
87 YJ 4.3l, TH350, 35's
95 YJ 2.5l, lifted, 33's
gmcz7198ba is offline
Crystal Lake, IL 4-Wheel Fest Oct. 3 ddoffroad Illinois Jeep Forum 1 09-29-2009 08:08 AM
Anyone going to the truck and Jeep fest in Atlanta? monjorrow Georgia Jeep Forum 2 08-22-2008 06:35 AM
Jeep Fest Copemish MI HavenSOV Great Lakes USA 0 08-21-2008 08:39 AM
Extreme Jeep Fest - July 13, 2008 - 9am-3pm CHRRRIS Illinois Jeep Forum 25 07-13-2008 09:40 PM
Southeast Jeep Fest Time!!! Nonstop Florida Jeep Forum 10 01-18-2008 08:54 PM
You may not post new threads
You may not post replies
