time to get a trailer - JeepForum.com
post #1 of 14 Old 10-01-2006, 07:43 PM Thread Starter
jipjip
jipjip's Avatar
it looks like i'm jumping on the boat w/ everyone else.
all the talk about going to tellico, uwharrie, moab.....
i will deff need to trailer my rig out there, as i don't trust it to go that long of a distance, wheel for a week, and then get me home.
so now i'm recruiting you guys to find me a decently priced trailer in my area (i know tom's good at this).
i would prefer electric brakes, but it's not manditory, just brakes in general would be good.
i don't want to spend over $1k, so cheap,cheap,cheap.
also, i will be towing w/ my dad's zj, so it's better not to be too heavy, as we only have a class 3 hitch on it, and that's only good for 5k.
happy hunting
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #2 of 14 Old 10-01-2006, 08:04 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
5K lbs and you're going to be cutting it close. With most car trailers weighing in at almost 2000 lbs, you're not gonna have much room left for the YJ and gear...
GOod luck either way!
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline
post #3 of 14 Old 10-01-2006, 08:11 PM Thread Starter
jipjip
jipjip's Avatar
i agree, but i don't have the money for a tow rig, and weight distribution hitch right now, so it's this, or bust...
jipjip is offline
post #4 of 14 Old 10-01-2006, 08:13 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Tis cool. It could work... just make sure that you take it easy, and the brakes on the trailer and ZJ are perfect!
post #5 of 14 Old 10-01-2006, 08:16 PM Thread Starter
jipjip
jipjip's Avatar
yeah, i might try something out for this run, and rent a u-haul trailer to see how i do. if that falls through, i may end up just getting a dolly just for the front wheels. which will be a LOT less weight, but it still keeps 2 wheels on the pavement, and if i break an axle, i could still be screwed. we'll see.
jipjip is offline
post #6 of 14 Old 10-01-2006, 10:04 PM
grandman97
grandman97's Avatar
i towed 2 700 lb quads and a bunch of supplies to PAP w/ my ZJ once and it was awful, the trailer probbly weighed less than 4k and i couldnt go more than 35 up the hills on I-81, the back tires rubbed in the wheel wells, and a week later the transmission crapped out, i would def. not reccomed towing ANYTHING especially a YJ w/ a ZJ
grandman97 is offline
post #7 of 14 Old 10-02-2006, 05:39 PM Thread Starter
jipjip
jipjip's Avatar
the trans in our zj just got rebuilt by a company out in utah, that does hd upgrades. we had the trans designed for heavy duty towing, so that's not an issue. we also have adjustable air bags inside the rear springs to help w/ heavy loads in the rear. the only real thing i'm worried about, is the weight dist. hitch that i may need. anything 5k and under you only need a class 3 for, but over that, you need a class 4 w/ weight distribution, brakes, and sway control....all of which i don't have.
i may just end up driving this time out, and looking into getting a tow rig in the end. but either way, i would like the look around for a trailer just in case anything good comes up in my area, so i don't miss out
thanx for the advice guys.
jipjip is offline
post #8 of 14 Old 10-02-2006, 05:56 PM
drewman141
Gas Guzzler
drewman141's Avatar
1994 ZJ
Andy - The uhaul full trailer is ridiculously heavy, somewhere close to 3K pounds and has a 4300lb load limit so I'm not sure that will work out for you. But like the others said pulling with a ZJ is not going to be fun. The main issue will be the quadra coil suspension. Since your load is so heavy it will be moving you all over the place and the ride will more then likely be horrible if not worse without a weight distributing hitch and some kind of sway control. That's my $.02
[SIZE="1"]2008 WK Overland HEMI - Modern Blue Pearlcoat
Fully loaded with slush mats of course.
MUST GO! 1994 Limited ZJ 5.2L V8 - Light Driftwood Satin Glow
It's a 94 5.2L Limited - trxus 33's on 15x7 steelies, 4.56s w/ front OX and rear trutrac, NP242 swap, novak shift kit, Kevin's ultimate 4.5" lift + ACOS, ARB front bumper w/warn M8000, rear tomkin machine bumper w/ tire carrier, kevin's hardore railz, kevin's ultimate tc skid, kevin's trackbar conversion, rusty's gas skid, flexalite efan, Kolak's performance ignition and brake upgrades. ViAir OBA, custom storage/sub box and I'm sure there's a bunch of other things I'm missing. Everything is a little over 3 years old with less than 10K miles. Looking to get around $4k.
drewman141 is offline
post #9 of 14 Old 10-02-2006, 06:24 PM Thread Starter
jipjip
jipjip's Avatar
how about just using a dolly for now... that way, there's less weight on the tongue, and the trailer won't weight much at all. as long as the front wheels will fit between the trailer wheels.
jipjip is offline
post #10 of 14 Old 10-02-2006, 06:30 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
That will def. help out with the ZJ, since most of the weight will be on the road... you will most likely fit with no problem on the dolly since the YJ is narrow to begin with..
I shall have pics of my new trailer tomorrow.
post #11 of 14 Old 10-02-2006, 06:35 PM Thread Starter
jipjip
jipjip's Avatar
so you found a trailer????
awesome, can't wait to see your new tow rig, trailer, and trailer queen together, like on big happy family
jipjip is offline
post #12 of 14 Old 10-02-2006, 06:47 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Haha yeah, one big happy, dirt poor, family..
post #13 of 14 Old 10-02-2006, 07:22 PM
gmcz7198ba
Just remember that on a dolly you have to use your tow rigs brakes to stop the ENTIRE load! With a trailer with brakes you can set the brakes just right, and if your good you can use the trailer brakes to help stop the tow rig!!
87 YJ 4.3l, TH350, 35's
95 YJ 2.5l, lifted, 33's
gmcz7198ba is offline
post #14 of 14 Old 10-05-2006, 12:52 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Hey Andy, do you need a towbar? I will sell you my ebay one for what it cost me + shipping if you want.
So Cal Trailer question cosninocanines California Jeep Forum 2 04-10-2009 07:55 PM
Find me a trailer ! nierace North East USA 9 02-10-2007 04:48 PM
CL Trailer TellyDSP North East USA 0 02-06-2007 10:07 AM
Need a Trailer? blakdot North East USA 6 01-16-2007 03:24 AM
Trailer (found another too) TellyDSP North East USA 17 12-07-2006 08:23 AM
You may not post new threads
You may not post replies
