Zip | 67210 |
Model | Wrangler |
State | KS |
City | Wichita |
Price | 75000 |
Shipping | Local Pick-up ,Will Ship |
Payment | Check/MO ,Cash Only |
This year has seen new wheels and tires as well as a new bed lined interior. New Hero 3 Speed and a new cover of Crawl Magazine. This is the only TJ on the face of the planet like this. Entertaining trades of well built JKU's that are dual purpose on road and off. Will trade up or down for the correct Jeep. The right Jeep would get me a good jump start but don't be surprised if I don't take yours. No bright color JK's. Black, silver, or billet only. 4 doors only. Not looking for a beat up piece of crap. If you have something nice let me know and we'll talk.
I have the clean Kansas title in hand.
Price tag to sell out right is $75k.
I have tons more pics if you are interested.
Image uploading. Refresh page to view
Well documented build thread:
Project: Dookey's revenge! - Pirate4x4.Com : 4x4 and Off-Road Forum
PM me if you want to talk. Walk if you want to low ball. I have tons more in it.
2006 JEEP WRANGLER RUBICON
DRIVE TRAIN
2008 L92 6.2L(403 hp and 415 lb·ft) from Cadillac Escalade(13k miles when pulled. 15, 500k current)
Custom Griffin Dual Pass Radiator and mount with high CFM fan
Matching 6L80e transmission with steering wheel tap shift tuned by Jim at Zero Gravity
Winters Shifter
Hero 3 Speed transfer case with 2.44 mid and 3.75 low
High Angle Drive Line drive shafts. Front and rear shafts can be swapped so you only need 1 spare.
Custom Motobilt Fuel Cell with Aeromotive Phantom 340 stealth fuel pump
Custom Trail Worthy Fab Fuel Cell Mounts with custom powder coat
Custom Fuel Cell enclosure
Custom Exhaust
Die Hard Platinum AGM Deep Cycle Battery
FRONT AXLE
Torq Axle 14 Bolt drop-out with Torq Axle custom housing. (Everything 100% Brand new when built)
Torq 14 bolt drop out
Wide Open Design custom truss
Reid Inner C's(Dana 70 forgings)
Solid GM Dana 60 Knuckles
Artec High steer arms keyed to solid knuckles
Reid Solid Bronze king pin bushings
5.38 Gears with solid pinion spacer. Sierra Gears
High Angle Drive Line 1410 Pinion flange
ARB Air Locker
4340 Chromoly Inner axle shaft
Yukon Super Joints
4340 Chromoly Outer axle shaft
TWF Dana 60 Drive flanges
Yukon Hardcore Dana 60 Lock outs
Off Road Gear Dana 60 Brake Caliper brackets
Wilwood 6 Piston Calipers
Wilwood 14" Street Rotors
PSC Full Hydraulic Steering with custom tie rods. Linked to Artec high steer arms in double sheer.
REAR AXLE
Torq Axle 14 Bolt drop-out with custom Torq Axle Housing(Everything 100% brand new when built)
5.38 Gears with solid pinion spacers. Sierra Gears
High Angle Driveline 1410 Pinion Flange
ARB Air Locker
4340 Chromoly Axle shafts
Off Road Gear Custom brake caliper brackets
Wilwood 4 Piston calipers
13" GM Rotors
SUSPENSION
Custom 4 link front and rear
EMF 1.25 Rod Ends with ¾" through bolt
Fox 14" Tuned Coilovers
Rear Currie Anti Rock
Front Currie Anti Rock
WHEELS AND TIRES x 5
17x10 Trail Worthy Fab Double D bead locks paint matched
43x14.50 TSL SX with 95% tread.
BODY AND ARMOR
Less than 30k miles on Tub/Frame
Trail Worthy Fab Rear Back Half kit
AEV High line hood
Rokmen High line fenders
PSC Front bumper with custom powder coat
PSC Ricochet Rockers
PSC Comp Cut rear corners - Aluminum
Warn Zeon 8s Winch - Factor 55 Pro Link
Motobilt LED light bar brackets
50" Trail Worthy Fab 4D Light bar
TruckLite LED head lights
American Superlite LED turn signals front and rear
PSC Laser cut roll cage with extra tubing
Mastercraft Baja RS seats mounted to the cage. Full recline, lumbar, sliders
5 Point harness for both seats
Autometer Guages
Full CB radio with external speaker
Garmin JEEP branded GPS on dash
Full Doors - New soft top
Trail Rated Badge
Mall Rated 4x4 Badge of Honor
Roots Vibrosonic Loud Horns
Grant Quick Disconnect steering wheel
Twist Machine Shrifter tap shifter to control 6L80e (With rev match)
LineX interior
STEREO
Kenwood head unit - USB, Bluetooth
Rockford Fosgate 4 Channel amplifier to control mids
Rockford Fosgate Class D amplifier to control subs with bass knob
Front 4x6 Polk Audio Components
Rear 6.5" Polk Audio Coax in CrawlTunes cans
2 - 12" Polk Audio Subwoofers
