2004 Jeep Wrangler Rubicon 115,000 Miles 4.0 L Straight Six You will not find another Jeep like this! Everything has been upgraded with top of the line parts and well taken care. This one of a kind Jeep is built to take you anywhere on any adventure and drive you home when you are done! The only reason Im selling it is I have a family of five. Its time for a jk four door! Upgrades done in this last year Aluminum radiator with built in automatic transmission cooler MADE IN AMERICA Waterless coolant Silicon radiator hoses upper and lower New thermostat and thermostat housing Flow cooler high flow water pump MADE IN AMERICA Goodyear Gatorback Kevlar serpentine belt Belt tensioner and tensioner pulley Idler pulley Moroso 7.5 quart oil pan and new oil pan gasket MADE IN AMERICA High flow oil pump flushed with Asmoil full synthetic MADE IN AMERICA New transmission pan with welded in magnetic drain plug powder coated blue New transmissions filter flushed with Amsoil full synthetic Transgo automatic transmission shift kit New Y pipe with two new Pre-cats ran to a Magnaflow muffler with turn down New all four two before cat and two after cat Mopar o2 sensors Here is the rest of the upgrades 5 X 15.0 Black rock LOBO wheels on 35 BFG KM2 tires Dana 44s front and rear with air lockers and 5.13 gears With powder coated blue diff guards NV241 Rock-Trac Transfer case with 4:1 gears K&N cold air intake Throttle body spacer Mean Green 260 amp alternator MADE IN AMERICA Blue monkey motorsports Speedo Healer MADE IN AMERICA Brown dog offroad 1 lifted poly motor mounts MADE IN AMERICA Champion double platinum spark plugs Stainless steel extended brake lines American rock rods hood lover kit MADE IN AMERICA Polly Transmission mount Sky jacker transfer case linkage JKS 1.25 body lift MADE IN AMERICA ¼ thick custom boxed lower control arm mounts front and rear axle Undercover Fab works deep cover package ¼ inch thick steel tummy tucked up 2.5 more than stock Cross member Main skid and engine/transmission skid all powder coated Black MADE IN AMERICA Rokmen ¼ thick steel gas tank skid plate 2.0 tucked up over stock black powder coat MADE IN AMERICA LOD offroad rear bumper with swing away tire carrier up to a 38 tire will fit With built in 55 watt back lights two jerry can racks over the top of spare tire storage rack Two inch receiver hitch 7 pin trailer lights extra frame tie in brackets MADE IN AMERICA Smity built 8,500 lb winch with synthetic winch line Metalcloak frame built front bumper with 26 stinger D ring mounts aluminum fairlead Light bracket license plate bracket MADE IN AMERICA Metalcloak front overline tube fenders with aluminum inner fender wells and Six inch removable fender flares with LED turn signal and marker lights All powder coated black MADE IN AMERICA Metalcloak Rear overline CUT tube fenders with six inch fender flares all powder coated black Metalcloak rocksliders powder coated black MADE IN AMERICA The front Metalcloak front tube fenders, rock sliders, and the rear tube fenders all tie into Each other to make a incredible armor package...MADE IN AMERICA Metalcloak steering box skid plate ties into front bumper MADE IN AMERICA!!!!!!!!! RockHard Full sport cage with two custom side bars for back seat all powder coated black MADE IN AMERICA 3.5 LOW COG custom suspension lift ALL MADE IN AMERICA Fully adjustable upper and lower control arms with flex joints (all 8 arms) Metalcloak 3.5 dual rate coil springs Rokmen rear coil spring relocate bucket with aluminum bump stops Metalcloak solid chromoly adjustable Trac-bars Mono tube shocks front and rear with built in bump stops Front and rear shock relocation brackets powder coated blue Front Currie Antirock torsion bar powder coated blue arms Tom Woods rear dub cardon drive shaft LED Rock light kit under all of the Jeep 1.25 inch seat raisers for better view Tuffy under driver seat lock box Daystar custom air vents rocker switches blue led back lit MADE IN AMERICA All Blue led interior lights dash, center console, shifter, and heater a/c control, dome lights, under the dash 50 Cree Led light bar 23,000 lumens KC headlight conversion Sony head unit cd, mp3, aux, usb, am fm with 3pre-amp out puts Kicker 5.25 2 way speakers in dash and overhead sound bar 100 watt x 4 channel amp Im sure Im forgetting stuff but you get the picture. A one of a kind Jeep built for any adventure with all the best parts. Very well taken care!
Look in my gallery for the pics of my jeep for sale
$20,000 or best offer
If you want to do all the shipping on your end and pay for it yourself after your payment clears that's fine
