$10,000-$12,000? feeler - JeepForum.com
Go Back   JeepForum.com > Jeep Classifieds > Vehicles For Sale > Jeeps For Sale
Register FAQ Search Today's Posts Mark Forums Read Unanswered Threads Search Members
$10,000-$12,000? 87 yj feeler
$10,000.00
hey there guys, im not planning on selling the jeep......yet, but was wondering what you guys think i could get for it and any advice on getting more for it.
its a 1987 yj. with a 258 4.2L engine and stock front and rear axles, transmission and a rebuilt (about 2 years ago, maybe 1000 miles) transfer case.
*VERY litte rust. any rust i find is usually attacked with a wire brush and then brought back to bare metal then repainted.
*4 inch Rubicon express lift with 33x12.5 dick cepeks on 15 inch american racing wheels. All under a year old. MAYBE 300 miles on them.
*all of the fluids (coolant, transmission, front and rear diffs, power strearing, washer fluid and engine oil) changed regularly. engine oil once a month with a quart of mystery oil every two months.
*front and rear end greased along with driveshaft.
*new radiator, hoses, thermostat and housing.
*weber 2 barrel
*soft top (with rear tinted plastic) has only been on for one year. i bought it new along with the soft doors two years ago and last year i had a hard top and doors on. sold the hard top but i still have the doors. spot of rust on them. besides that that have been rebuilt and greased and are awaiting paint. black.
*new radio and polk audio speakers along with, i believe, a 6 inch bazooka tube.
*new battery
*new starter solenoid
*new starter
*new battery terminals and wires
*aftermarket seats from summit
*center console
*new valve cover gasket
*new rear main seal
-no sludge in oil pan
*new oil pan gasket
*new distributer cap and rotor
*new e3 plugs
*new wires
*new ignition coil. epoxy 40,000
*new fan clutch
*new belt
*all black hood and hinges along with mirrors
*new 6 inch fender flares to cover tires
*new fuel filter, fuel pump and stainless steel brake lines
*2 year old cat back. will be putting in new header and complete exhaust system.
*new headlights
*custom front bumper
*110 lumen lights on front bumper.
*new timing chain and housing 2 months ago.
*i also have a new extended driveshaft and sye that i haven't put in yet.
bad.
*there is a connection issue at times with the driver side brake light. works if you turn the blinker on. (maybe you guys have some ideas on that one)
*another issue it the headlight switch is acting up and the lights will shut off at times for a few seconds. i did find the short and would fix before selling.
*the tailgate hinges are sagging so in order to close it you have to pick it up a little bit.
*the odometer reads 110,000 and the title says 111,000 but i had a mechanic take a look at it and he says it has been rebuilt and has maybe 60-80,000 miles on it.
over all this jeep is awesome.
thanks
p9210160.jpg   back-drivers.jpg   driver-front-wheel.jpg   driver-hood.jpg   hood.jpg
[]lllll[]
87angler 87angler is offline
View all my items
Tags: feeler
Listed on: 03-02-2013, 01:13 AM
Listing #15063602
Viewed: time(s)
State: MA
City: nantucket
Zip Code: 02554
Model: Wrangler
Payment: Check/MO,Cash Only
Shipping: Local Pick-up
Have a question? Contact the seller.
Report this item.
share a link to this item
share a link all items by 87angler
Share this item on other forums
Embed on eBay!
Unread 03-02-2013, 06:43 AM   #2
yellow_dolphin
View My Classifieds
 yellow_dolphin's Profile
What Jeep model and year? Pics will also help.
2002 TJ Sport (Rebuilt)
2006 TJ Unlimited Rubicon
1982 CJ8 Scrambler (Sold)
yellow_dolphin is offline   Reply With Quote
Unread 03-02-2013, 07:06 AM   #3
Duck Doctor
View My Classifieds
 Duck Doctor's Profile
What engine, transmission, and axles? How did you mechanic determine that the engine has 30k-50k miles on it than the odometer reads? Did the previous owner abuse the rig causing premature engine failure?
Duck Doctor is offline   Reply With Quote
Unread 03-02-2013, 07:59 AM   #4
1slo_camaro
View My Classifieds
 1slo_camaro's Profile
The fact it has a 2bbl weber carb i would say you are reaching for the stars at 10k at this point we can only assume and i am assuming youre trying to get rid of a YJ or CJ since nothing else except maybe old XJs ran carbs. But like already stated we need details of the actual vehicle
94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60'Sold/Stripped, 1992 Camaro RS 305 700r4 Convert.
1998 ZJ Grand Cherokee 4.0 4 RC super flex, JK shocks, 703 injectors, 60mm TB, 2000XJ intake, TB spacer, HIDs, TJ fuel bezel, Mickey T Classics with 32x1150, Black Soft 8s with 31x1050 (winter) awaiting stroker and 3in spacers with 35s
"Life is full of decisions, You make them and don't look back"
[B][U]PM me for 99+ intake manifolds for sale[/U][/B]
$50-bare
$60-sandblasted unpainted
$75-sandblasted and painted
1slo_camaro is offline   Reply With Quote
Unread 03-02-2013, 08:12 AM   #5
87angler
1987 YJ Wrangler
View My Classifieds
 87angler's Profile
and i edited the description so it has some more specs.
[]lllll[]
87angler is offline   Reply With Quote
Unread 03-02-2013, 08:32 AM   #6
Jawbox
View My Classifieds
 Jawbox's Profile
At the price, first make sure it's mechanically perfect. Steering tight, no vibrations, no ticks or odd noises. When a person looks at a vehicle, the more 'little' things they find, the more they assume that they are going to find other issues.
The brake light issue might be the turn signal switch, I think mine did something similar. I picked up a replacement at rockauto for under $20. I borrowed a steering wheel puller and had the job finished in about 20 minutes.
The Diamond Plate under the door is going to be a red flag. Most people will assume that any area with diamond plate is hiding rust even if it is perfect underneath, the finish on the doors will probably be another issue.
Honestly though, even if you fix all that, $10-12000 is probably a stretch, especially on a carbureted YJ. It's a great Jeep, but at that price you're up against some great condition TJ's and really nice restored CJ's.
Jawbox is offline   Reply With Quote
Unread 03-02-2013, 08:41 AM   #7
87angler
1987 YJ Wrangler
View My Classifieds
 87angler's Profile
thanks for the advice on the brake light issue Jawbox. ill try that out in the next couple of days. i was going to add something about the diamond plate there. i know that that is a prime rust/body damage sign. it is perfect under them though. siliconed water tight. just through it on there to cover the existing holes from the stock step. i am painting the doors to either match the top or do a gloss black with in the next week or so.
[]lllll[]
Unread 03-02-2013, 10:46 AM   #8
1998tjsport
1998tjsport's Avatar
View My Classifieds
 1998tjsport's Profile
Honestly it is basically a sotck (axels, motor, trans) early yj. It is in good shape but still not perfect. I would see this jeep going for 5-6k around here if you are lucky. At 10-12k you can buy a TJ rubi or a mint sport....
WTB INCA GOLD HALF DOORS PM ME
Current-
2003 INCA GOLD TJ Rubicon 5 speed 3inch Currie/Savvy Lift, JKS Discos, 305 KM2s
Build Thread
http://www.jeepforum.com/forum/f22/f...ld-up-1447047/
Past-
1994 Grand Cherokee 5 SPEED 3inch lift, tj bumper, 31x10.5s, wheel spacers, rhino liner, ect.....
1998 TJ Sport 5 Speed 31x10.5s, completely murdered out, and a short throw haha (miss that jeep)
1999 TJ SE 5 Speed (ls swap that became a part-out due to excess frame rot)
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
1998tjsport is offline   Reply With Quote
Unread 03-02-2013, 11:46 AM   #9
jeepcrazy93
Jeeper
View My Classifieds
 jeepcrazy93's Profile
Yep thats about what I think. Even though it looks nice, I would be surprised if you got over 6-7k
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline   Reply With Quote
Unread 03-02-2013, 11:58 AM   #10
alaska_djz
View My Classifieds
 alaska_djz's Profile
$4,500.00 tops. So many yj out there with more and better mods (axels for example) for cheaper than $4,500.00
alaska_djz is offline   Reply With Quote
Unread 03-02-2013, 01:16 PM   #11
1slo_camaro
View My Classifieds
Phew i hate to beat ya down dude but my old mans 95 yj body was a little rougher with a 5spd 2.5 lifted on brand new 33s interior replaced hard and soft top with some bolt on we barely got 2500 for it. But hell its your jeep you can ask whatever you want. But just realize that you might hold it for awhile look on craigslist at what similar jeeps are going for in your area?
$50-bare
Unread 03-02-2013, 02:28 PM   #12
djflyy
Adventure Is Out There
djflyy's Avatar
View My Classifieds
 djflyy's Profile
Being in the region, I can say you might find the right rich'ole bastard on ACK to buy it for $10k to furnish the summer house they'll never be at.
For a Jeep guy, nobody will go near $10k.
Boston Jeep Build Thread
North Shore Jeeps Website
Originally Posted by StuddMuffinz View Post
dj, it amazes me how your jeep can always make me happy in the pants <3
djflyy is offline   Reply With Quote
Unread 03-02-2013, 04:49 PM   #13
sjsst41
1978 CJ7
View My Classifieds
 sjsst41's Profile
That could be an accurate response if it was a CJ, but the YJ's don't seem to command the same $$$ with everything being the same condition. If it had FI, that would help, but I'd estimate $5 - 6k as well. You can post it for as much as you want, and work it from there, that'll be the only way to really figure out what's it worth. I've seen CJ's in similar condition in NE go for that price, but never a YJ.
sjsst41 is offline   Reply With Quote
Unread 03-02-2013, 06:58 PM   #14
Ripper3494
AUTASTIC
Ripper3494's Avatar
View My Classifieds
 Ripper3494's Profile
i listed my yj for 10 and only got one hit on it and it was a lowball lol i can see that selling for 6
build thread:
http://www.jeepforum.com/forum/f22/9...-spud-1218315/
1997 ZJ limited - BONE stock
http://www.jeepforum.com/forum/f12/a...te-up-1301614/
http://www.jeepforum.com/forum/f12/t...ation-1417686/
RC vs BDS
http://www.jeepforum.com/forum/f12/r...s-bds-1461555/
Ripper3494 is online now   Reply With Quote
Unread 03-02-2013, 10:14 PM   #15
87angler
1987 YJ Wrangler
View My Classifieds
 87angler's Profile
thats exactly what i was thinking djflyy. i would never expect to get that much from a jeep person, but i have plenty for time to find that right buyer considering i still want it and have no need to sell it yet. thank you everyone for the input and information.
[]lllll[]
The time now is 10:34 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
