Wrangler Wheels on a Grand Cherokee - JeepForum.com
post #1 of 9 Old 10-26-2013, 12:42 AM Thread Starter
rheals
2008 WK
Hi everyone. Question about fitting wheels from a wrangler on my JGC. I have a 2008 CRD Grand Cherokee and found a used set of wheels from a 2013 wrangler sahara that I was hoping buy. Has anyone tried fitting wrangler wheels and tires on a grand cherokee? Here are the wheels and tires I am looking at purchasing:
Wheels:
Jeep 7 spoke polished sparkle wheels
18" x 7.5"
5 on 5 (5 on 127mm) bolt pattern
6" back space
44mm offset
Tires:
Bridgestone dueler a/t
P255 70R18
Two questions: 1) would they fit and 2) would I have any issues with tire pressure sensors?
I would appreciate any insights anyone might have.
Thanks!
Ryan
2008 JGC 3.0L CRD QDII
GDE EcoTune, 2013 JK 18" Wheels
rheals is offline
post #2 of 9 Old 10-26-2013, 02:06 PM
jpat30
The wheel itself will fit just fine. The "new" JK and WJ (99-04) share the same bolt pattern. The tires that come on them might be another story. They might rub a bit especially if you use you jeep for anything other than paved roads. Check out the WJ forum here and type JK wheel into the search feature; you will find more info than you probably have time to read.
-Carpe Diem Phil 1:20
jpat30 is offline
post #3 of 9 Old 10-28-2013, 09:35 AM
WXman
Also, the Wrangler wheels are 6.0" backspacing and I think the Grand Cherokees were always 5.0 or 5.5" so you might have rubbing issues on the upper A-arms regardless of tires. This is not an automatic "it'll work" in my opinion. You'll need to test fit them first.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #4 of 9 Old 10-28-2013, 03:40 PM Thread Starter
rheals
2008 WK
Thanks WXman. I will do a test fit for sure. Does anyone know if 2013 wranglers come with tire pressure sensors? If so, would they communicate with my 08 JGC?
rheals is offline
post #5 of 9 Old 10-29-2013, 12:29 PM
WXman
Yes they do have sensors, and no they won't work on your GC. They changed the frequency/protocol in 2011.
WXman is offline
post #6 of 9 Old 10-30-2013, 07:46 AM Thread Starter
rheals
2008 WK
Thanks. Thought it was a long shot anyways!
rheals is offline
post #7 of 9 Old 03-31-2014, 04:00 PM Thread Starter
rheals
2008 WK
Just to follow up... I purchased that 2013 set of 18" jeep wrangler wheels and put them on my WK. I bought some 1/4" spacers, but turns out I didn't need them. The wheels fit and I haven't had any rubbing issues. The inner sidewalks of the front tires are pretty close to the suspension bolt, but they clear. I will have to order some TPMs eventually. Plan is to bolt on those bilstein 5100 adjustables all around. I'm thinking 2 inches will be the perfect lift. Thanks for your input everyone.
rheals is offline
post #8 of 9 Old 03-31-2014, 04:01 PM Thread Starter
rheals
2008 WK
*sidewalls not sidewalks
rheals is offline
post #9 of 9 Old 06-12-2015, 06:44 PM
BIGSTAN
2008 WK
Tire question
How are you making out with that tire combination that you posted a couple of years ago.....I have found the same combo also....I think either a 2" lift or wheel spacers would make them work great!! Please reply, I may do the deed in a couple of days!! Thks!!
BIGSTAN is offline
