worn front tires help! - JeepForum.com
post #1 of 6 Old 01-30-2013, 02:31 PM Thread Starter
mainemudbilly
I bought a set of tires brand new and 6 months later my rear tires are still brand new but my front tires are bald was hoping someone else may have had same issue I was thinking tie rod ends and ball joints but the tires wore evenly across
Cross the mountains and through the woods to the beer store we go
mainemudbilly is offline
post #2 of 6 Old 01-30-2013, 02:33 PM Thread Starter
mainemudbilly
I got 285 70 17 tires with 1.25 wheel spacers
post #3 of 6 Old 01-30-2013, 02:37 PM
Agent620
Take it to a shop and check the alignment.
Agent620 is offline
post #4 of 6 Old 01-30-2013, 04:19 PM
Unlimitedlou
Your toe is probably off. Look for a thread on doing an alignment and save some coin and do it yourself.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #5 of 6 Old 01-31-2013, 07:54 AM
mdm
Farm Wheeler
I agree that the most likely cause is the toe-in. Was the toe-in checkes after the 4" lift was installed? Changing the suspension height changes the toe-in. A 4" lift will result in about 1 to 1-1/2 inch of toe in when you should have about 1/8 inch. This will cause the tires to scrub wearing them out quickly.
It's too late to do anything about your front tires now. If they are really as bad as you describe, I'd just buy a new pair and get the alignment checked.
http://www.stu-offroad.com/steering/align/align-1.htm
Regular rotation is very important also. Rotate every 3000 - 5000 miles. The more aggressive the tread, the more frequently you should rotate.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #6 of 6 Old 01-31-2013, 03:45 PM Thread Starter
mainemudbilly
Yea I read up on the DIY alignment seems easy and I know tires are screwed but I wanted to figure out the issue before I bought new tires
ball joints , tie rods , tires
