WJ wheels on a WK - JeepForum.com
post #1 of 1 Old 11-23-2013, 03:47 PM Thread Starter
samger2
WJ wheels on a WK
I know there are lots of questions out there as to whether WJ wheels will fit on a WK or not...well I thought I did my homework, but I must've missed something.
I have a 2005 WK and wanted some cheap wheels to run snow tires on, so I found a set of WK 17" wheels...the bolt pattern is the same, and according to wkjeeps and wjjeeps the backspacing and offset is the same, so I bought the wheels. So I mounted up the tires and balanced them and put them on at home tonight.
As soon as I backed out of the garage I could hear the grinding. The front wheels grind on the calipers.
How can that be if the offset, back spacing and bolt pattern all should be identical? Any thoughts?
samger2 is offline
