Winter Tires
Lots of threads around here about AT tires. Lots about MT tires as well. Lots of thread bashing or praising Brand X or Brand Y. Lots of size vs lift height threads, too--so many of those...too many!
Not as much discussion out there about winter tires, and since winter is on its way again, I thought it might be nice to put together a solid thread about winter tires.
I'm going to begin with an winter tire overview, so if you're only interested in a list of recommended tire models, scroll down til you see it, but I would like you to read the whole post if you can.
First of all: I won't be calling them "snow tires," and I'd ask you not to either. Why? They're not just for snow. A study conducted by the Traffic Injury Research Foundation (http://www.tirf.ca/about/index.html) found that winter tires provide significantly greater traction in ALL conditions whenever temperatures are 7 deg C (~45 deg F) or below (http://tirf.ca/publications/PDF_publications/2012_Winter_Tire_Report_7.pdf). All condtions. If it's 30 degrees outside and the road is completely dry/clean, winter tires are still superior. If it's 40 degrees and raining...winter tires. If you live somewhere that regularly sees temperatures below 45 deg F, you should seriously consider having a set of winter tires to use. I will discuss how this actually ISN'T much more expensive for you in the long run (if at all) to further down the page.
What IS a winter tire? The basics of winter tires consist of soft rubber, lots of siping/kerfs, and commonly directional tread patterns. The reason that other tires (yes, this includes AT and all season tires despite their names) perform so poorly in winter compared to winter tires is primarily due to the rubber compound used. As the rubber gets colder, it gets harder. The soft rubber used to make winter tires keeps them nice and pliable at low temperatures. This soft rubber is also what makes them wear very fast and can also make them dangerous in warm temperatures, so please do not use winter tires year-round (there can be exceptions to this, but not many). Lots of edges to bite with are also extremely helpful. Siping/kerfs are what achieve this, and you'll commonly see winter tires being much more heavily siped than other tires. Zig-zag siping is also extremely common--more surface area to bite with compared to a straight line. While far from mandatory, directional tread patterns are common due to the superiority of directional tread patterns to evacuate water and slush. Heard of hydroplaning? Slushplaning is actually a thing that tire manufacturers concern themselves with when designing winter tires, too.
Below is a comparison between two tires at the top of their respective categories (my opinion). Cooper AT3 representing all terrain and Nokian Hakkapeliitta R2 SUV representing winter.
I would like to point-out that the Mountain/Snowflake symbol does NOT denote a winter tire. It is the severe winter service symbol, but all that means is that the tire attains "110 compared to the ASTM E-1136 Standard Reference Test Tire when using the ASTM F-1805 snow traction test with equivalent percentage loads." That's a fancy way of saying it has at least about 10% better traction than the "average" tire. That standard may have been raised to 20% or some such higher level, but it's still a poor system and misleads and misinforms drivers. Frankly, that's almost as piss-poor as the M+S standard that used to be used which dealt with grooves and voids...basically any tire could be manipulated to be described as adhering to the M+S standard and not necessarily be any better off in mud or snow.
Studs. Oh, studs. Yep, studs are a very common option on winter tires. Studs generally increase ice and hard snow traction. I'm not a fan of studs. Studless tire technology is pretty much to the point where studs are obsolete. Studdable winter tires tend to be better with them, but there are numerous studless tires where studs aren't even an option, have no need for them, and even out-perform studded tires. Studs also have downsides. It isn't uncommon for a tire to suffer reduced dry and wet traction when studded vs no studs. Many states have also restricted or even banned stud use due to the increase in damage inflicted on roads. You can find information about what the laws regarding studs in your state (or other states) are using one of the links below.
http://drivinglaws.aaa.com/laws/studded-tires/
http://www.rma.org/tire-safety/seas...ded-snow-tire-regulations-for-passenger-cars/ (as of 2013)
Some people believe that lowering (or raising) tire pressure will assist in winter traction. This is incorrect. Like every other time of year, you want your tire's tread to make even contact with the ground. Lowering tire pressure will reduce the center tread's contact with the ground and cause increased wear on the shoulders, causing reduced traction and premature tire demise. Raising pressure will cause increased wear in the middle and reduce the shoulders' contact with the ground also reducing traction and causing increased wear on the middle and premature tire demise.
That being said, some manufacturer owner's manuals recommend higher winter tire pressure. Below are some of Tirerack's theories regarding this:
Yes, there are all season and all terrain tires that perform admirably in winter. For the most part, they tend to be the best of the best of their respective categories, and no, they don't hold a candle to the winter performance of a top winter tire. You're simply kidding yourself if you try to convince yourself that your Hankook 727, Cooper STT, Goodyear Silent Armor, Michelin MS2, etc is as good in winter as a good winter tire. There are some tires that do bridge the gap both from the all season/terrain side as well as from the winter side of the gap so well that they're worth mentioning, and I will mention these later when I discuss some of the best and/or most popular winter tire choices.
Most people seem to shy away from winter tires either because they don't think/know they need them OR because they think they can't afford them. We're all Jeepers here. I'm sure the vast majority of us have dropped stupid amounts of money on our rigs just for fun over the years. If you can afford toys for your Jeep, you can afford winter tires. Most winter tires are CHEAPER than their all season/terrain counterparts. Cheaper. Yes, this cost is in addition to the all seasons/terrains that you regularly buy as well, but that only matters the first time you buy winter tires. HUH?!
For simplicity's sake, let's say you spend $400 buying tires every 4 years. $100 per year annual budget. Most winter tires are cheaper, but it's also not uncommon for them to have slightly shorter tread lives, so we'll just say that evens-out and they cost exactly the same to keep this simple. The first time you buy winter tires, you'll spend $400 you otherwise wouldn't have. Well, you'll need wheels to mount them on. Winter is tough on wheels, so don't buy fancy, expensive wheels. Get some cheap steelies or buy some used wheels off of Craigslist or something. Let's say $50 per wheel; depending on your needs/taste, this could be more, or it could be less. We'll also say you're only buying 4 because what good is a full size spare on what has a high probability of being a directional tire (only 50% chance it'll be useful on the side you need it on). So we're up to a$600 buy-in. Yeah, that's not cheap, but how many of us have dropped $600 or more on lifts? Bumpers? Armor, racks, lights, winches, etc? You can also save toward this over a year or two or more if necessary if you want winter tires. You've lived without them til now, you can wait until you've saved enough if you're not made of money.
Once you have a set of winter tires, your long-term tire budget will STILL only be $100 per year. WHAT?! Why not $250 or $200 per year? Well, you only need to buy wheels once, so there's that. Also, when you're driving on your all season/terrains, your winter tires are accumulating 0 miles. When you're on your winters, your AS/T's are accumulating 0 miles. You replace tires when they wear-out, right? Well, they'll last longer time-wise now--you'll still be spending them same amount of money per mile driven on tires, but now you'll have much better and much safer traction in the winter.
Switching? Again, we're Jeepers. It's not much to jack the Jeep up and swap wheels twice a year. You should be rotating your tires anyway, so sync your swap up with a Spring/Fall rotation. Just make sure to keep track of where your tires were when you take them off so that you know where to put them back on such that they'll have been properly rotated. If you really can't do this yourself, there are many shops that will do this very very little cost, and it's not terribly uncommon for a shop to do it for free especially if you're a customer and double especially if it's one of those places that you have a free lifetime rotation perk with.
Storage? I don't have any fancy advice here. If you really don't have room to store 4-5 tires, then you don't have the room, and I suppose you're one of the few people who really can't make winter tires work for them. Since they get stored for months at a time, I suggest you consider asking a friend or relative if they have space to keep them for your before you give up completely however. You only need to access them twice a year after all.
So, what tires do I recommend? Well, there are so many. I can't make a list that will work for everyone, so I'll make a list that will have some use to MOST of us around here. This isn't an exhaustive list. There may be great tires I don't list. There may be models I list that don't come in a size that works for you. I also won't be going in to great detail about the pros and cons of each of these tires. While I will try to order them roughly in order of my preference/recommendation, There are pros and cons. Just like any other tire category, one tire may be better for one person than another person. We can discuss them in detail as the thread progresses. This is just me trying to be helpful, and if you want more personalized assistance, I help many people via PM and would be happy to help you, too.
- Nokian Hakkapeliitta 7 or 8
- Nokian Hakkapeliitta R or R2 SUV
- Nokian Hakkapeliitta LT2
- Hercules Avalance R G2 (yes, it does look like a Hakka R clone, doesn't it; I promise I didn't accidentally use the wrong photo)
- Michelin Latitude X-ice Xi2
- Bridgestone Blizzak DM-V1
- General Altimax Arctic
- Continental ExtremeWinterContact
- Yokohama iceGUARD iG51v
- Hercules Avalanche X-treme
- Cooper Discoverer M+S
- Toyo Observe GSi-5
- Goodyear Ultra Grip Ice WRT
- Firestone Winterforce
So, what if you want to use the same tire all year long and want to come as close to the best of both worlds as possible? This is a very short list as far as I'm concerned. These aren't just tires that do "well" in winter. These are the ones that I can personally recognize as living in the large gray area between winter tires and the AS/T's--they have set themselves apart from the rest in regards to winter for one reason or another.
- Nokian WRG2 or WRG3 (aka WRA2/3, WRD2/3)
- Goodyear Wrangler Duratrac
- Cooper Discoverer ATW (this is an estimation; this tire is new and has not proven itself yet)
Honorable mentions (again, these aren't necessarily exhaustive lists; there are so many tires in the world, and I'm just human):
- Goodyear Silent Armor
- Kumho AT KL78
- Kumho AT51
- General AT2
- Firestone LE2
- Hercules AT2
- Hankook Optimo H727
