Will Replacing Front MT Tires Reduce Noise? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Will Replacing Front MT Tires Reduce Noise?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRugged Ridge Deals at JeepHut.comRough Country Lift Kits and Parts!
Unread 02-02-2015, 10:58 AM   #1
ExtremeCreature
Junior Member
2008 WK
I have a WK with Nitto Trail Grapplers on it that have worn unevenly and are getting quite loud. Additionally one of the tires has been cut somehow and has a very slow leak. So I'm wondering... If I buy 2 new tires for the front and leave two of the existing tires in the back, will that make a big difference in the noise level? Or would I need to buy 4 new less aggressive AT tires?
2008 GC Overland - 5.7L V8 Hemi – QD II - OME lift (HD front/MD rear) - JBA UCAs - AEV Argent Pintlers – 265/70 17 Nitto Trail Grapplers - Superchips Flashpaq
2002 GC Limited - 4.7L HO - QD SOLD
ExtremeCreature is offline   Reply With Quote Quick reply to this message
Unread 02-02-2015, 02:10 PM   #2
mdm
Farm Wheeler
Tire noise level is in the ears of the listener. If they are worn unevenly, tires will usually be louder than new or evenly worn tires. Some tires will get louder with wear even if they are wearing evenly.
Less aggressive AT tires? That's a decision only you can make. They will be quieter than what you have now.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 02-02-2015, 05:33 PM   #3
ExtremeCreature
Junior Member
2008 WK
Thanks for the response. I guess what I'm wondering is does the majority of the noise heard in the car come from the front tires when driving at a higher speed? And, has anyone just replaced the fronts with new tires and experienced a dramatic decrease in the noise level?
Unread 02-03-2015, 11:19 PM   #4
Redbob
On my 04 WJ, I recently rotated uneven wearing front tires to the rear and got not only dramatically - reduced nouse, but also much less vibration.
Redbob is offline   Reply With Quote Quick reply to this message
Unread 02-04-2015, 08:32 AM   #5
Tshark299
1987 YJ Wrangler
In my experience the uneven wear often caused by the front adds a lot of extra noise to an aggressive tire. I try to rotate them as often as possible to prevent as much unevenness as possible.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parted out the rest
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is online now   Reply With Quote Quick reply to this message
Unread 02-10-2015, 10:00 PM   #6
ExtremeCreature
Junior Member
2008 WK
Thanks for the feedback everyone, and particularly Redbob. Just got around to responding. This is exactly what I was looking for. I suspected that replacing the fronts would dramatically decrease the noise, but wanted some confirmation before proceeding. Otherwise I was going to replace all four tires with much less aggressive ATs. Anyhow, I replaced the fronts this morning and the result was... "not only dramatically - reduced nouse, but also much less vibration". It did make a huge difference in the noise and vibration. All of my tires had worn very unevenly (lift maybe?) even though I tried to rotate them regularly. I don't know why they were worn so bad (unevenly), but I was getting a lot of vibration and noise, and now it's much better. Thanks again!
Unread 02-16-2015, 07:43 AM   #7
karlo
Had the Trail Grapplers and they're relatively smooth and quiet on the highway. If you want less aggressive, Terra grappler's are a good option.
karlo is offline   Reply With Quote Quick reply to this message
