Will a 12.5" wide tire fit on a 7" wheel? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Will a 12.5" wide tire fit on a 7" wheel?
Win a $250 Gift Card to ZoneOffroad.com - 4th of July FaceRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-09-2011, 11:39 AM   #1
dblplay1212
I have stock grizzly wheels (15x7) and would like to put some 33/12.5/R15 on them but worried about width. I won't be using these but a few months and won't be wheeling when I have them. Just something to put on the Jeep while it's mid-build.
I searched around but didn't find what I was looking for. Thanks in advance.
dblplay1212 is offline   Reply With Quote Quick reply to this message
Unread 08-09-2011, 05:16 PM   #2
jeepyj13
Its possible and has been done but it will be a tight wrap around the rim.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline   Reply With Quote Quick reply to this message
Unread 09-09-2011, 05:46 PM   #3
LYTSOUT
any more insight as to why it's suboptimal? might they pop off or something either onroad/offroad, or with 35psi/15psi? or damage/rub something?
hate to poach but i'm wondering the exact same thing and i'd feel like a choad starting a new thread with the same question only to get hazed by dudes with 5000 posts saying "use the search, noob". haha. anyway, i'm tring to weigh 31 vs 32 vs 33 and 10.5 vs 11.5 vs 12.5 on my 15x7" grizzlies +/- 2" BB. thx guys.
LYTSOUT is offline   Reply With Quote Quick reply to this message
Unread 09-10-2011, 03:28 PM   #4
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You can mount a 12.50 wdie tire on a 7" wide wheel. I put 35-40k miles on a set of 33x12.50 tires on 7" wide wheels.
Its less likely the tire will come off the wheel compared to a wider wheel.
Were you planning on using wheel spacers? If not, the 5.5" backspacing that Grizzly wheels have will likely cause you some problems. What kind of Jeep do you have?
Wheelin98TJ is online now   Reply With Quote Quick reply to this message
Unread 09-11-2011, 02:27 PM   #5
LYTSOUT
sorry, i'm new to the forum and didn't realize i didn't have my jeep's specs in the profile or sig.
so the 5.5" backspacing on grizzlies will make 12.5's rub inside my tj? could that be fixed with wheel spacers, if so, how big would i need? if not, is there anything else i could get to prevent rubbing?
'99 TJ sport hardtop
4.0L, manual
32" duratracs on 17" moabs, otherwise stock
Unread 09-11-2011, 02:44 PM   #6
mattwillard06
I have 285/75/16 (32.8x11.2) stock rubi rims with 5.5 of backspacing they rub on full turn on the track bars. I have been told to either get wheel spacers or new rims but nobody has said how much. I know that with your tires being 1.3 inches wider they will rub. I also have 2 inches of spring lift. If your just trying to get by during your build I would say just don't turn sharp n you should be fine
mattwillard06 is offline   Reply With Quote Quick reply to this message
Unread 09-11-2011, 03:43 PM   #7
Wheelin98TJ
JEEP FREAK
1.25" wheel spacers will work.
Unread 09-13-2011, 10:54 AM   #8
LYTSOUT
what about 32x11.50? i'd like to keep my stock grizzly rims and avoid wheelspacers. i'm reading stuff on these forums that rec against them. think 32x11.50 would work? maybe with adjusted steering stops?
4.0L, manual
Unread 09-13-2011, 11:05 AM   #9
Wheelin98TJ
JEEP FREAK
11.50 will be very close or it will rub the upper coil perch in the rear.
You should stick with 10.50 max width if trying to use Grizzly wheels without wheel spacers.
Unread 04-03-2015, 01:13 PM   #10
rkcustoms
hello I have just rebuilt my yj every has been renewed etc 4.5" rough country lift my problem lies when I drive it, seems to be all over the road. I have 33 12.50 r15 tyres mounted to stock rims with 55mm hub centric spacers. all steering joints are new and just had tracking (wheel alignment done) the only thing we can find is that the tyres are two wide for rims giving a balloon type effect crowning. making the jeep act wrong. I've ordered some 10j rims hope this sorts it any one had this problem thanks
rkcustoms is offline   Reply With Quote Quick reply to this message
