Wich tire width for 10inch beadlock ? - JeepForum.com
post #1 of 6 Old 02-09-2016, 05:22 PM Thread Starter
Aragard
I just bought 10 inch wide beadlock, what tire width should i go ?
I currently have a deal on baja claw but 12.5, shoud i be ok?
Thanks !
Aragard is offline
post #2 of 6 Old 02-09-2016, 10:17 PM
christensent
2014 JK Wrangler
Nothing wrong with a 12.5 on a 10 inch wide rim. Many people would prefer to put a 12.5 wide tire on an 8-9 inch rim because it helps keep the bead seated when aired down to have the tire squeezing out, but that's less of an issue with beadlocks. If you wanted to, you could certainly run a 13.5-14.5 tire on that rim.
christensent is offline
post #3 of 6 Old 02-10-2016, 02:09 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
12.5 wide tire on a 10" wide beadlock works great.
Why are you concerned?
You could run anywhere from a 10" wide up to a 16" wide tire on those wheels.
Wheelin98TJ is offline
post #4 of 6 Old 02-10-2016, 04:12 PM Thread Starter
Aragard
My concerne are on low pressure on trail, like 5-10 PSI. I don't know if i'll lose bead...
Aragard is offline
post #5 of 6 Old 02-10-2016, 04:59 PM
Wheelin98TJ
JEEP FREAK
That concern was addressed with beadlocks.
You can go down to 1-2 PSI if you want.
Definitely go lower than 10.
post #6 of 6 Old 02-10-2016, 05:41 PM
biffgnar
biffgnar's Avatar
This. Once you go below 5psi you'll understand what real traction is.
biffgnar is online now
